Question about Pentax K200D Digital Camera with 18-55mm lens
Used Vivitar 70-200 zoom on my K200 Pentax. Nothing but aggravation since. Right now the 18-55 lens it came with is on but shutter button is stuck in down position and my flash wont pop up using the manual "up" button. When I look thru lens and push button, flashing "F" is the only thing there. Removed lens and button would move enough to "click" but would not come up. Put lens back on and nothing! Newbie in the extreme and ready to go back to my MX !!
  • carick Aug 04, 2010
    Can't see that having anything to do with the flash not popping up plus the lens worked fine before my using the manual zoom.
  • 3,866 Answers
The issue here is the manual mechinsm is in defect, Your going ot hate me but there is not much I can do over email but to tell you a local camera shop can take care fo this for cheap. Whats going on is the mechism is jammed most of these are spring loaded once down in locked position and mech jammed the camera will need to be opened and repaired. Do not shoot the messenger facts are facts, over email there is not much that can be done, To tell you the trueth.
Let me know if you have any additinal question
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 04, 2010
  • carick Aug 06, 2010
    Thanks much. Can't say I like your reply since I live about 150km from a "big city" with a camera shop but I had a feeling I'd fixed it up good this time. Moral - read book first. Trouble is, it's such a BIG book!
  • 10,319 Answers
There is a short in the circuitry of this lens or bad contacts that don't make contact
Hi, have pentax k100 d, like new taken very good care of. Stored with batteries removed. Now all I get are low sound clicks firing only when button is pressed. Went into menu and opened shutter and turned...
Sounds like your shutter is stuck. Given that the camera is only worth about $100 -- or even less -- it's probably not worth sending in for repair. You can buy a good used "upgrade" like the K200 or even the K-50 for about what a shutter replacement would cost.
Mar 23, 2018 | Pentax Cameras
Can I use Vivitar Mc 50mm F1.7 Lens on Nikon D3200 ?
Vivitar makes lenses with a variety of lens mounts to fit different brands of cameras. If the lens has a Nikon mount then it will work on the D3200. If it has some other mount then it will not work.
Feb 27, 2014 | Vivitar Pentax Mc 50mm F1.7 Lens Pk...
Where can i get a zoom lens that is pk mount friendly. i am in phila., pa.
Any local shop that deals in Pentax products, or used gear should have K-mount lenses. If not, you can search new and used selections at KEH Camera, B&H, Adorama, Calumet, and other's online for reasonable prices and have a good idea and generally a guarantee of what you're getting. You may also have luck on ebay, but chould be hit and miss. Any Pentax K-mount lens, by Pentax or any number of other maker's would work fine.
Aug 18, 2011 | Vivitar V3800N 35mm SLR Camera
What does smcp -fa mean
SMCP- means: Super MultiCoated Pentax (a term that refers to the anti-relctive coatings that Pentax has been using on its lenses for years F-means it is a lens designed to cover the larger area required of a lens for Film camera use versus the smaller sensor of the Digital SLRs Pentax also makes. Pentax also makes DA lenses , which will only work with their digital SLRs. A- means it will work in fully automatic mode on cameras that have the ability to set shutter speed and F-stop automatically (most modern Pentaxes) It should also be noted that all DA and FA pentax lenses have a modified version of the original Pentax K lens mount, which replaced their first lens mount, the universal M42 used by so many early film SLR manufacurers- this concluded todays pentax lens history
Jun 02, 2010 | Pentax Zoom Wide Angle SMCP-FA 28-105mm...
Vivitar lens to Pentax K-x camera adapter.
It depends which camera they were originally designed for use upon. If they are M42 lenses, then yes, but without any automatic facilities whatsoever - if not, then it is unlikely.
If you sign on to this link as a guest, you may find answers there. Pentax Forums The Ultimate Resource for Everything Pentax
May 29, 2017 | Kodak LENS ADAPTER 49 TO 55MM Lens...
Film Advance Lever is loose, shutter wont work when I press the Shutter Release Button. viewfinder is black
If your viewfinder is black, the mirror on the film camera is up. That usually means the shutter system is out of whack... Repair would be too expensive. You can by a used Vivitar, Pentax body as a replacement as they use the same non AF K-mount lenses for pretty cheap. But again, they would be old cameras.
Oct 11, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Lense problem
Dear The pro,
The vivitar v2000 definately takes pentax lenses but only k mount lenses.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 09, 2008 | Vivitar 600-1000mm (1200-2000mm) Super...
What does my zoom lens fit?
The lens fits in vivitar, pentax,cosina cameras
Mar 10, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Blurry pictures with Pentax K1000
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Take care & Happy Imaging!
Glen
Sep 06, 2007 | Pentax K100D Super Digital SLR Camera
Pentax K200D Digital Camera with 18-55mm lens Logo
80 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
