Question about Samsung Heating & Cooling
My Samsung is mounted in the wall of my office. Once I turn the air conditioner off,it starts to leak water for several minutes. Any way to stop this? Frank
  • 456 Answers
When the unit is on, go on the back side of the wall where the unit is
mounted. If this is a split system find the condensate hose and make sure it is not plugged and is draining.
If this is a window unit again go in the backside of the wall and see if it
is dripping there. If it is not, take the unit out of the wall, remove the top
and wash underneath the coils. Install the unit so it slants to the back.
Posted on Aug 04, 2010
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
How do i stop the leak on my panasonic air conditioner
You need to blow out the drain hose, it's clogged. You can use a water hose to flush out the line.
Sep 19, 2014 | Panasonic CS-MKE12NKU Mini Split Wall...
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
We have model # MW09C1E/MW12C1E indoor unit - wall mounted type Has started to leak water - not sure if it is the pump that has stopped working - we have cleaned the filters and the vents in the front...
Many do not have a pump and the drain simply plugs... blow it out with air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Friedrich Heating & Cooling
THE AIR CONDITIONER LEAKS WATER FROM THE FRONT OF THE UNIT.
Look for the drain line coming out of the unit typically in the bottom. Clear out this drain line with a vacuum or water hose. It should begin to drain and stop leaking.
If the leaking continues, you may have a cracked drain pan or severe drain blockage.
Jul 31, 2010 | LG Goldstar GWHD5000 wall/window Air...
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
Sep 14, 2009 | Frigidaire FAC126P1 wall/window Air...
The air conditionner is mounted on wall and is leaking water
The Unit must be lower at the back end and higher than the drain hose if using one.
Aug 23, 2009 | Samsung Heating & Cooling
Mitsubishi Air Conditioner FDKN Series leaks water after 30 mins
It could be one of two things -
1) The unit is not hanging level (assuming this is a wall mount, through the wall, or window unit), or
2) The condensate drain or trough to the drain is plugged/clogged/filled with trash.
Jan 22, 2009 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
