Question about Cameras
When i turn on camera it flashes a screen that says card set up power off
    President:
  • 1,944 Answers
Try formatting the memory card in an external card reader.
Posted on Apr 26, 2008
I have a canon t3i. The menu doesn't turn on when you turn on the camera.
The menu doesn't display when you switch on. You should get the settings screen appear. Once powered up just hit the MENU button
Mar 02, 2015 | Canon EOS Rebel T3i 600D SLR Digital...
My sony DSC H10 cameras flash isnt working what could it be?
If the flash is not functioning, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
This should resolve the issue.
Thanks for using FixYa.
Jan 27, 2011 | Cameras
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My camera flashes lightnot working how can i fix it?
Jan 16, 2011 | Sony Cyber-shot DSC-H10 Digital Camera
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
My camera won't turn on!
Check your memory card you need a sd card or mmc for this camera make sure your card is not an sd hc card over 2gb it will not support it
Feb 14, 2009 | DXG Technology DXG-506V DV Digital...
It wont turn on
Check the memory card try to turn on the camera without the memory card if that works problem with the memory card if that doesnt work...... Try using a diffrent set of batteries...... Still doesnt work...... Get the camera replaced..... Good Luck....
Jan 19, 2009 | Nikon Coolpix L11 Digital Camera
Digital camera R717 - display screen
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 20, 2008 | HP Photosmart R717 Digital Camera
Olympus FE-210 Camera Problem
Format the card, this error idicates that some required data is missing from the card .
Feb 26, 2008 | Olympus Camedia C-350 Digital Camera
Card Set Up Error
xD or compact flash? If its the xD, format it in a Fuji camera at a camera store (just ask to see a demo and explain to the guy you want to see if the camera will work with that card...) Fuji seems to format cards better than Oly, even the tough ones. If it is compact flash, look inside the socket for any bent pins, common for that type of card.
Oct 28, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Cameras Logo
201 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
