Question about Toshiba 36A42 36" TV
Tv will not stay on
Was changing channels heard a crisp pop! TV shut down power light flashes. Un pluged tv , plugged back up light quit flashing tv came on with a light blue picture and white diagonal lines running across the screen1 Help!!
    Genius:
  • Toshiba Master
  • 1,689 Answers
A common cause is a short occurred in the electron gun of the CRT. This usually causes collateral damage to support components in the CRT drive circuits.
The set will require proper shop service to determine the exact failure. I personaly would not invest any money in a set of this age. I would consider replacing it with a new LCD type.
Jerry G.
Posted on May 15, 2009
Flashes 6 to 7 times
mine has done the exact same thing, and apparently ( have yet to try) there's a second fuse in the tv and that's the problem, now I need to locate the fuse!!! lol mines an older Philips, let me know if yours is the same problem
Sep 06, 2013 | Panasonic TC-P50G15 50 in. Plasma HDTV
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
TV won't stay on! The TV will randomly make a "click/pop" sound and turn off. I will unplug the tv for a bit and then reinsert power cord. The tv will "click" (just like when it is turning on) then a...
Power supply board have problems.It dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 14, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Tv just shut off, so i un-pluged it for a few, turned it back on green light flashes for about 20 seconds then red lamp light flashes, tell me the bad news
Yup.. it's bad.. sounds like a typical Switchmode power supply fault or some other fault that is shutting down the PSU, to stop any more problems and prevent a fire etc. I guess it cannot hurt to obtain a firm "Quote" for repair from a reliable service center?
Mar 04, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Toshiba 50H81 Sound but no picture
if you heard a pop that would be a capacitor unable to take the voltage, hopefully no other damage, you will need to identify the capacitors that have gone and replace the parts with the same number ie 40v 300uf 105c remember don't touch the 400v or 200v capacitors as they will still have power in them, discharge them by placing a metal object over the + and the - on the capacitor and then the board will be safe.it could also be the bulb has gone. you would need to check this as if the bulb has gone the tv will shut down. and flash but usually there is an led that flashes to tell you bulb failed.
May 28, 2017 | Toshiba 50H81 50" Rear Projection...
Tv is pluged in,will not come on when on button is pushed
is the unit competly dead? no flashing lights.first unplug the set for 30 min then plug back up and try again if there is no lights then i suspect main fuse has blown. however this does not mean replaceing will fix. something has shorted to cause fuse to blow if there is flashing then the computer in the set has seen something wrong and shut down.
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Av-32d302 tv
The set is shutting down because a problem has been detected. Replacing the remote will not help. Count the flashes and call a JVC servicer to get an idea about what the specific problem may be.
Dan
Jul 29, 2008 | JVC AV-32D302 TV
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Toshiba 36A42 36" TV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
