Re: Cannot get remote speakers to come on - the light on...
Hit the multi source button then hit the button of the input desired (cd,dvd, ect) then hit remote speaker button. Controll remote speaker volume with the remote control.
If you pulled the cover and only see one fuse, and if it is not blown, then you need to search deeper for the problem. All replaceable fuses on the main board are viewable.
Speakers have nothing to do with spontaneous power ON. It either has a severe and dangerous internal power circuitry issue or it's sensing a remote control command to turn power on and off. Block thereceiver so it can't possibly see any external controllers and see if that stops it.
You could verify if any speaker wires being shorted is the problem by just disconnecting all of them and trying to power it up. If it fails to power up, it's sick and needs a hands-on tech to look at it.
If you don't actually SEE the problem while disconnecting the speakers, but the receiver DOES come on, try reattaching one at a time until you either have found the offending speaker/wire combination or you have success in turning it on and using it.
Speakers can be shorted, too. So if you locate a channel giving you trouble, say, front right, you could swap a different speaker or wire set into its place to prove if it's external or internal to the receiver.
Going forward, make sure you don't run the unit too loudly and give it plenty of room for cooling ventilation.
I had the same problem. You must turn on the remote speakers via the reciever and then adjust the remote speaker volume control that is only located on the remote control. The volume buttons are on the top right of the remote. It is briefly discussed in the owners manual which can be downloaded online.<!-- from fixya rte -->
The rear speakers will only work when the Dolby signal processor or one of the 4 sound fields has been selected. In other words, the rear speakers won't "work" when listening in just Stereo, and this can happen if the "By-Pass" button on the front of the receiver has been engaged.
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at [email protected] and I will send you a copy of the manual. Thank you. Onkyo USA
Hello, I am sorry about your issue. I suggest that you contact Onkyo product support at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA.
