Question about Ruud Heating & Cooling
How do i clean the evaporator coil on my ruud 3 ton unit .
  • 407 Answers
The best way that I have found to clean the evap. coil when it's clogged with dirt and other things is a small wire brush and some evap. coil cleaner that is self rinsing. You will have to open the coil box and take the small cover off of the coil itself which can be a pain sometimes. You might have to take the flue apart and clear other obstacles that can get in the way. The self rinsing cleaner has to be bought at a A/C supply store. Be careful not to bend the aluminum fins has this could add to the problem. Also be sure that you don't leave a lot of junk in the drain pan or it might also be clogged later. One more thing that a lot of people forget to do is clean the coils on the outside unit as well. This can be done with a water hose and a spray gun. Starting from the top, work your way from left to right and heading down. Also be careful not to bend the aluminum fins here too. Hope this helps!
Posted on Aug 05, 2010
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
RUUD Achiever 3 ton roof unit. Pops fuses. Place "hard" fuses in and it would pop the house's 60A fuse. Checked both motors and they spin just fine at the touch. Both caps also...
The compressor is going bad or the unit is charged wrong...
Whatever the cause the problem is the compressor locking up and blowing the fuses...
Clean the condenser coil...maybe the pressures are going too high...
If that don't work, then the compressor is shot or over charged...
Here is a tip that I wrote about how to clean your condenser
Cleaning Air ConditionerCondenser Coil with Pictures
heatman101
Jul 25, 2011 | Ruud UBHC Air Conditioner
I have a Ruud Achiever series 5 ton outside airconditioner - model UAKB060JAZ. It is 5 years old. All of a sudden it wants to freeze up and it has my plumber baffled.
Freezing up is usually from low freon or insufficient air flow across the evaporator coils.
Don't choose a plumber to fix your A/C unit. ;p
May 02, 2011 | Heating & Cooling
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
Part number for an evaporator coil for a ruud system model number for the condensr is UAHE-023JAS I dont find any numbers on the coil. Can you match it up?
i can tell you it is a 2 ton unit. 24,000 btu's. the only other thing you need to know is the width and the depth. they make a 15 inch and a 19 1/2 cabinet. hope this helps you.
Jun 09, 2010 | Heating & Cooling
Have Rheem 5 ton heat pump with stacked coils poor cool.
If your sure on the psi your low on freon or your evaporator is restricted discharge psi would realy help.you will get best performance with a clean unit or pay expensive utility bill . Tom
Jun 18, 2009 | Ruud Central System Air Conditioner
Residential HVAC - Repair vs Replace? Heat Pump? Two Stage AC?
for 65 dollars i would replace the coil I do however love gas and heat pump combos it will cut your gas bill by about 75% only uses gas below 30 deg
you may want to try a honeywell 8000 stat it has random circulation fan comes on and just circulates the air also used for gas hp combo with an out door sensor and you don't need the fossil heat kit as for the copper if possible replace it due to don't trust any ones soldering as for units the are all about the same look for warranty some replace unit others have life time comp if only going to be in house for 10 yrs hard to recover cost give replacement allowance when sell
May 11, 2009 | Ruud UBHC Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Evaporator coil
Follow the copper line set from the condenser. Yhat will be the yellow brick road to tne evap coil.
Aug 16, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
418 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
