Question about Kitchen Ranges
Jenn air range, model CVG4280B, repair, ignitor problem. Ignitors will not work on any burner. Burners can be lit manually. Power is available at the electical box. Fan comes on when either burner turned on to the left burners only not when right burners turned on.
  • Anonymous Sep 28, 2008
    I have the same problem
  • jybreton Jan 13, 2009
    everythings works except the igniter. When I turn the knob I don't hear the tick, tick I use to hear when the igniter was functionning properly. Is the blue box the defective part?
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
Jenn-Air CG206B. All ignitors don't spark or click. How would I know if it is the Spark Module or the Spark Ignition Switch. And cost if possible for parts and labor. Thank you.
one thing to be sure is there power to the range. if you can light the burner with a match your gas is good, If all burners are affected it can be a broken wire, power source, or spark module.
always unplug electricity before attempting to repair on any electrical appliance
Sep 07, 2017 | Jenn-Air Cooktops
Jenn-Air dual fuel ignitor problems
Replace the igniter on each one and you should be ok.
Oct 20, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
The ignition keeps on sparking after the burner is lit.
How old oof a unit is it? The burners switches when on will operate ignitors for all burners no matter which switch is "turned on". Usually when units get older these switches on the most "often used" burners will stick and stay "connected" then all ignitors will continue to spark this is also true if switches accidentally get wet with spillage or water till they dry out. No danger though because jsut because ignitor is sparking doesnt mean gas is being released, gas is only released when valves are turned on
May 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Feb 15, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDR8895 dual fuel--ignitors won't work after flood
hi your ignitors wont last long, they are similar to a fuse, you should be able to change the ignitor and if it still does not ignite look to see the space of the ignitor and try shorten it.
Feb 05, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor would not turn off on front left burner
Same problem with the ignitors on the burners myself.  But only when i turn on the left side burners do they continually spark.  Any one know what ignition module on this?  How does it prove flame?  To ground?  Might I have a bad ground causing it to not rectify the flame?
May 16, 2008 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn Air Pro Style gas range - ignitors on 2 burners (same side) click but don't light
I had a problem in which only one burner refused to light with the electronic ignition, even though the same ignitor (they are shared) would light the rear burner on the same side, and the problem burner would light with a match. On inspection, the spark occurs at a central point and there is a tube which apparently leads gas from each burner to the ignitor. There are two groupings of 3 holes each on the sloping part of each burner, facing toward the ignitor. After lighting both burners (the front one with a match), I saw that the lower group of 3 holes had tiny flames on the burner that worked properly, but not on the other. I carefully cleaned each of these holes with a small pin, and the problem appears to be solved.
Apr 27, 2008 | Jenn-Air Kitchen Ranges
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Kitchen Ranges Logo
479 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
