Question about Canon PowerShot S3 IS Digital Camera
My camera worked fine for 3 years, when suddenly .... when i'm zooming fast (zoom button pushed down) camera switches of. If i'm zooming slowly everything is ok. Some master said that zoom lens motor was demagnetized. Need change motor. Is it true and is it possible to buy this motor from you and what could be price? thank you.
    Sergeant:
  • 313 Answers
I would say to check the batteries and their connecting surfaces plus the contacts in the battery compartment. With bad connections on the batteries, when the camera zooms slowly it does not use much power. When zooming fast it uses more power (current) and if the batteries are making a poor contact the camera will shut down due to low volts. Check that first before spending big money. If you are using Duracell batteries, they have a short + pip end which some devices will not work with them due to poor conection. Compair a duracell battery with another brand. see the difference on the + end.
Posted on Aug 04, 2010
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Aug 18, 2007 | Sony Handycam CCD-TRV37 Camcorder
Zoom lever stopped working on Panasonic lumix DMC-FZ8
Does it say anything about the lever under zoom levers in your owner's manual?
Nov 07, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
I switch the camera on. I get 3 beeps and it shuts down.
The problem is of zoom lens motor which operates lens cover along with zoom, and it needs replacement with new part, and camera will start working fine again.
Thanks for using fixya
Jul 26, 2009 | Samsung Digimax S600 Digital Camera
Zoom feature not working
So you're pressing the Zoom button but it has no effect, am i correct?
There can be 2 issues - small (dust/moisture), not small(inside button gone bad).
Small Issue: Keep the camera in sunlight(not very hot) for a while. (not loaded). Wipe off with clean lint-free cotton cloth. Keep it again in sunlight for a while. If moisture is the issue then it should go off, though i have seen in some cases it took 3-4 days and suddenly it started working.
If still no response from Zoom then the internal zoom small button has gone bad and needs to be replaced. Send it for repairs.
May 30, 2009 | Polaroid T831 Digital Camera
Instruction on zoom operation and also operation of flash on came
u have 3 problems here zoom,the flash and language ,ok to change the language hit menu .button then first word that shall be setup menu then word on the line number 3 and use right and left arrows to change ,the flash .turn the camera lens wheel on the pyramid sign u see on the front of the cam and then use the push button right side with zigzag sign to switch the flash mode ,push the button then up and down to zoom in and out
Mar 21, 2009 | Vivitar ViviCam 3750 Digital Camera
Zoom doesn't work anymore
camera lens is malfunctioning and needs repair
Jul 10, 2008 | Olympus FE-280 Digital Camera
Need to set the date and can't find manual--
Try this:
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Dec 22, 2007 | Canon Sure Shot 115u II Date 35mm Film...
IXUS 700 zoom problem
contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
Oct 30, 2006 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot S3 IS Digital Camera Logo
100 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
