Question about Leviton 15a 120v Sp Switch
I am installing a Leviton combo switch and tamper resistant outlet. The outlet appears to have plastic behind the holes. What do I do?
  • 565 Answers
Just plug in an appliance. Equal pressure from _both_ of the prongs of the appliance opens the plastic plates. Inserting a _single_ object into a _single_ slot (such as what a child may try to do with a metal object) will not allow the plastic plates to open.
That's the criteria for an outlet to be considered tamper proof anyway.
Posted on Aug 06, 2010
Testimonial: "thanks"
How you install a light and plug in in one switch
1) Copy following link for wiring combo device:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
2) Neutral wire is required for outlet to work.
3) Outlet will be ON all the time.
Some combo devices can be wired so that switch controls outlet, but other models cannot be wired so switch controls outlet.
Look for break-away fin located between dark screws on combo device. If device has break-away fin, then switch can control outlet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 21, 2013 | Leviton 8299 Combination Switch / Smart...
I AM TRYING TO REPLACE A LEVITON 5225 SWITCH IN MY KITCHEN. DO YOU HAVE WRITTE INSTRUCTIONS ON THE NET AND IF SO, HOW DO I DOWNLOAD THEM, OR BRING THEM TO MY COMPUTER FOR READING?
Leviton 5255 is a switch-outlet combo
Open following link for illustration and written instructions for combo wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Add a comment if you have trouble with wiring.
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on switch or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 27, 2011 | Leviton 5225WSP Switch and Outlet
We are trying to install a Leviton No. T5225 Combination switch and tamper resistant outlet. We are replacing the single light switch with this new one. We have a red, a white, and a black wire. When we...
You are installing a combo device with switch and outlet.
The outlet is tamper resistant so a child cannot stick a key into outlet and get shocked.
For the outlet to work, a 2-prong plug must be inserted.
Wiring the device:
Electricians don't guess, they test.
Device has different colored screws: dark, silver and brass.
Separate wires for testing.
Do not unwind wires that are twisted together.
White wires that are twisted together and located in back of box are included in testing.
Use ordinary 2-lead tester.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. This wire connects to dark screw.
Hot is identified.
Test Hot wire to all other wires, except bare ground wire.
Tester lights up on Neutral wire. Neutral connects to silver screw.
If you do not have a Neutral wire, then outlet will not work for that location.
You can get the outlet to work by connecting bare ground to silver screw, but that is violation of code.
Last wire goes to Load (light, fan, motor).
Load wire connects to brass screw.
In your case, this is red wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on switch or any do-it-yourself project.
Jan 19, 2011 | Leviton 8299 Combination Switch / Smart...
I have a Leviton Combination Switch and Tamper Resistant OIutlet. Switch is on top. 15A-120V AC/CA 15A-125V and want to install it. Not sure how to connect with wires from wall so that the on/off...
Do not break off fin.
FYI: Tamper resistant outlet must have prong in both outlet-holes before there is power.
This prevents child from sticking something into one outlet-hole and getting shocked.
You are installing combo switch and plug.
Device has dark screws (with break off fin), and 1 brass screw and 1 silver screw
Let's test wires using ordinary tester.
Separate wires, turn on power.
Do not untwist wires that are twisted together.
Test each wire to bare ground wire. Tester lights up on hot wire.
Hot wire goes to dark screw.
Hot is identified.
Test Hot wire to all wires except bare ground wire, but including white wires that are twisted together,
Tester lights up on Neutral.
Connect neutral to silver screw.
If you do not have Neutral, then you do not have wires needed to connect outlet part of device.
Outlet can be powered using ground wire in silver screw, but this is not code and I am not recommending this action.
There is one wire left that does not light up when testing,
This is wire goes to load (lights, fan, motor) ... connect this wire to brass screw.
For a price, fixya expert speaks with you over phone while you work on switch or any do-it-yourself project.
Jan 13, 2011 | Leviton 15a 120v Sp Switch
We are replacing an old switch plug combo with a leviton T5625. We have two black wires, two white wires and ground. The old combo just had one black wire connected to the screw on the right side of the...
Leviton T5625 has shutter (tamper resistant) mechanism that blocks access to the contacts unless a two-prong plug is inserted. My understanding is this mechanism prevents child from sticking piece of metal into receptacle and getting shocked. Tamper resistant receptacles are code for new home construction, and receptacle is marked with TR. The light switch part of device works at all times, with or without two-prong plug in receptacle.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=388754§ion=24614&minisite=10026
Electricians test, they don't guess.
Let's test your wires using ordinary two-prong tester.
Tape wood sticks to tester leads to keep hands away from power. Stand on dry surface or wood boards. Do not shake or sweat.
Turn power ON.
Tester lights up on Hot wire. Hot wire connects to either dark-colored screw, as long as there is a brass connector plate that connects both dark colored screws. If connector plate is missing, add a jumper wire between both dark screws so they are connected together.
Hot wire is identified.
Now test Hot wire to each other wire, except bare ground wire.
Tester lights up on neutral wire. Neutral wire connects to silver screw.
If neutral wire is white wire, AND both white wires were connected together before, then they both connect to silver screw.
The last wire is the Load wire that goes to fan, light, motor. Load wire connects to brass colored screw.
Double check instructions with instructions on new device.
Add a comment any time.
You can also take advantage of fixya phone service.
For a price, fixya expert speaks to you over the phone while you test and wire the device.
Dec 28, 2010 | Leviton Electrical Supplies
How do you install a combination switch & tamper resistant outlet
I can help you but need more information. Please be more specific about what you are trying to acomplish
Oct 27, 2009 | Leviton 15a 120v Sp Switch
Leviton 15a 120v Sp Switch Logo
223 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
