Question about Kenmore 72055 Air Conditioner
Forgot how to reset ac unit when it shuts itself down after xx hrs of use.
  • 857 Answers
Step 1
Locate the shutoff panel on the house wall next to the outdoor compressor unit. Turn the unit to the "Off" position.
Step 2
Locate the 240 volt circuit at the main electrical panel of your home. Turn it to the "Off" position.
Step 3
Wait five minutes or more and turn both back on, restoring the power to the unit and resetting it.
Posted on Aug 04, 2010
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
Gnerator not producing ac power
I recently had a similar problem during "Sandy". I forgot to turn off the hot tub before starting the generator and the house lightswhere barely lit, dim, and flickering under the load. I quickly shut itoff andthe hot tub, but not before frying half of my generator. It will only produce 110now, not the 220 usual adn I need to get it fixed. I imaging you may be experienceing the same thing if you can't reset it. My generator has two reset buttons right next to the outlets on the unit itself.
Nov 03, 2012 | Electrical Supplies
I recently bought a used RV Carrier AC unit for my older camper. After installing the ac will work for about ten minutes before the breaker trips. If I reset the breaker the problem will repeat itself. ...
It sounds like the compressor is opening a thermal overload which is shutting the unit off. When the compressor cools down the switch resets and the process repeats itself. In the end it sounds like the system has a leak and is therefore low on Freon. This will cause the compressor to overheat and open the thermal overload. The freon cools the compressor windings and if it is low they will not be cooled sufficiently and hence the opening of the overload, which is a bi-metal sensitive to heat/cold.
If this has helped you please take the time to give me a rating on FixYa.com
Aug 03, 2011 | Heating & Cooling
I have a duotherm rooftop ac. fan runs fine but when comppressor starts it runs for 5 or 10 seconds and shuts down
I'm not familiar with these units so this is very general. Your compressor could be shutting down due to low pressure. You would need to get the refrigerant charge checked. It might be due to an overload tripping, which would then reset itself. If you had a schematic or something to send me I could tell you more.
May 05, 2010 | Dometic Rooftop RV Air Conditioner
My mitsubishi 52725 shuts itself off after acouple hrs
Its most likely the thermal fuse which is causing the problem. It gets up to operating temp then shuts down.
Jun 17, 2009 | Mitsubishi WD-52725 52". Rear Projection...
My momrex mmp8565 is telling me it's having trouble booting up and then shuts down
Read you manual p. 59
http://www.memorexelectronics.com/manuals/MMP8565CFirstDraft10-9-07.pdf
If the unit acts erratically, reset the unit by inserting a thin object (such as a paper clip)
into the recessed Reset button. For the Reset button, see page XX for the
button's location.
FOR FIRMWARE UPGRADE
Please visit our Web site at www.memorexelectronics.com to check if there is new
firmware available.
IMPORTANT NOTE: Before upgrading the firmware, please backup all of your media
files on your computer. After upgrading, format the unit to complete the upgrade
procedure.
Sep 07, 2008 | Memorex Audio Players & Recorders
Lap top will not power on
repair shop job- button replacement if possible.
May 15, 2007 | HP Pavilion ze5185 Notebook
Kenmore 72055 Air Conditioner Logo
50 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
