Question about Brother SE-270D Computerized Sewing Machine
The sewing machine does not operate. on the screen shows the presser foot lever is raised but its already lower.
  • 1 more comment
  • tatyana_drob Aug 20, 2010
    Its doesn't help.
  • tatyana_drob Sep 03, 2010
    Still doesn't help
    I'm not sure how correct cleaning or replacement this . Foot lever looks good.
    President:
  • 1,961 Answers
Check the switch at the foot lever it might need a cleaning or replacement this might brocken or shorted replace it with new switch if cleaning dont work good luck..
Posted on Aug 21, 2010
  • 15,935 Answers
What model # is this question about please??
Thanks!!
Posted on Aug 04, 2010
  • 2,272 Answers
Title:
"Lower the presser foot lever." appears on the LCD. Description:This message appears when the start/stop button, reverse/reinforcement stitch button, thread cutter button or the foot controller is pressed while the presser foot lever is raised.
· ----- Proper operation will sound
One beep------
· ------ Improper(wrong) operation will sound
Two or four beeps-----------
There is a lever behind the pressure foot that can be raised to allow you to lift the foot to put the fabric in place. When your fabric is under the point of the needle, lower the lever to put the foot down onto the fabric.
If the lever is down and its still showing the message that "lower the pressure foot lever" then try this procedure.Remove the thread/fabric completely out.Then remove the needle as well.Then clean the thread passing area.Now raise the lever completely up then lower the pressure foot lever.Do this same procedure for 5 to 10 times.Then again re-thread the unit fit the needle.Try to sew and check if same message comes up.If still the same message is seen then check if the pressure foot lever is got loose or looks like cracked or out of its alignment.If this is the lever needs to be checked and readjusted and replaced if its cracked.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 16, 2010
My feed dog will not go back up with leaver in back
Are you talking about the presser foot lever? That lever raises and lowers the presser foot. If you are talking about the feed dogs, there is usually a lever to raise and lower the feed dogs. Consult your owner's manual.
Jun 19, 2018 | Sewing Machines
I took apart my sewing machine, Brother CE1100PRW, to clean, and "Error 1" would not go away, please help.
Brother says:
The foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) and the reverse/reinforcement stitch button was pressed while the presser foot is raised.
Lower the presser foot lever before continuing the operation.
An E1 message appears on the panel Brother
Apr 13, 2018 | Brother Sewing Machines
How do you use the buttonhole foot on a babylock companion 1550
1.Mark position and length of buttonhole on fabric.
2.Set button on the base and slide base forward to secure button.
* If button does not fit on the base, adjust slide on base to diameter of button plus thickness of button.
a= Length of button + thickness
3.Pass upper thread through the hole of buttonhole foot and attach buttonhole foot to machine.
Bring upper and bobbin threads to the left under foot.
4.Position fabric under presser foot so that the center line mark is in the center of the needle opening in the buttonhole foot. With the main part of the foot pushed to the back, lower the presser foot lever.
5.Lower the buttonhole foot lever so it is positioned behind the raised finger on the foot (see step 5 illustration). a
Note:Machine will not start to sew if buttonhole lever is not lowered properly or buttonhole foot is not positioned correctly.
Note:If machine does not reset for second buttonhole, be sure the presser foot raised finger is pressed against the lever.
6.Hold upper thread lightly and start the machine.
Ref. :babylock.com/downloads/manuals/
Oct 05, 2017 | Sewing Machines
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
If the presser foot lever is already lowered and on the screen is lower the presser foot lever. What is this?
try turning it off & then back on
I've encountered the problem with my electronic sewng machine
it jams up & I turn it off & then turn it back on, that usually clear the circuit board
if it keeps doing it, I would suggest taking it to be serviced
Jul 29, 2010 | Brother SE-270D Computerized Sewing...
When I attach the embroidery arm and turn on the machine I get an error to raise the presser foot lever even when it's already raised and it won't work at all. Works just fine without the embroidery arm...
My moms does the same. One way we got around it was to hold the presser foot all the way up and click the ok button on the screen. The other thing we did would be to hold the presser foot up all the way while turning the machine on while the embroidery unit was already attached. When I say raise the presser foot all the way up, I am talking about raising it up as if you were placing something really large under the foot, not just in the resting up position. Hope this helps - it is very frustrating! My sister has the same exact machine purchased at the same time as my moms, but she doesn't have this problem.
Dec 08, 2009 | Baby Lock Esante
My sewing machine is flashing E1 AND I DONT KNOW HOW TO FIX IT Dottie
Error code E1:Make sure the presser foot is lowered before sewing.
In order to get this error the foot controller has to be pressed (or the start/stop button was pressed if the foot controller is not connected), and the reverse/reinforcement stitch button needs to be pressed while the presser foot was raised.
The only solution offer by Brother is to lower the presser foot lever before continuing.
This seems a bit simplistic so assuming you tried that already
Check to make sure there is no tangled thread interfering with the take-up lever.
This seems to be a common problem and it may be related to a computer issue rather then a mechanical fault.
In this case you may need to have the machine serviced.
I hope something here helps. I will investigate more and if I discover anything else I will pass it on.
Nov 13, 2009 | Brother CS-6000
Presser foot lever won't lower the foot
This may be a lubrication problem on the presser foot shaft. Try freeing up with penetrating oil or Triflow. After letting set for an hour lower the presser foot and pull down on the ankle. If that does not work you need to open the machine and loosen the clamp screw on the presser foot shaft. Then try to twist the shaft to loosen it up.
Nov 21, 2017 | Janome Sewing Machines
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
I have a Brother LS 15 sewing machine
raise presser foot to highest level pulling wheel toward you(counterclockwise) release the foot assembly with the lever at the back of the foot holder assembly place you quilting foot in line with the slot on the shank lower the presser foot lever on the shank if it is where it should be the bar will snap in and you should hear an audiable click or snap let me know if this helps
thanks amy
May 12, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
199 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
