Question about Garden
I have a troybilt super bronco mower. the steering wheel flange was wearing out often and eventually i had to replace the steering gear when teeth went bad. Now the steering wheel flange has worn out the metal of the frame(or plate) that it inserts into. i don't see a replaceable part for that...
  • joey642 Aug 04, 2010
    The problem is not finding a part-is there a part or something else i can do to get steering when the flange has worn out the place it fits into?
    not many options with this problem but maybe i can get it welded-thanks
  • 6,826 Answers
I'm afraid that if the flange has worn out and the parts are not available, you may have to have a welding shop fix it for you, if you have a good one in your town.
Good luck on this repair.
Posted on Aug 04, 2010
    Genius:
  • 1,478 Answers
I will advice you check www.ebay.com to order for the part of your troybilt super bronco mower. The site sell all parts and full equipment of all device.
Take care.
    but that's what I'm saying-there doesn't appear to be a part for this-the flange has worn out the plate in the frame or body. i have the manual but this is not really a part to be purchased (that i can tell anyway)
Tightening steering wheel on husqvarna tractor 42in 15 horsepower no. yth1542
Interesting! The steering gear can commonly become loose at a several points. I would check the steering wheel itself, prise off the central plastic cover and make sure the nut underneath is tight. Check the gear at the bottom of the steering wheel shaft, if this gets loose it can jump the gear teeth. Sometimes this is so bad the steering wheel will turn without moving the wheels. Tighten everything and replace any worn parts.
Jun 13, 2016 | Husqvarna Garden
How to make gears/teeth on lower part of steering line up on 268-H T Wheel Horse line up? Rmove deck, orwhat? There is some wear on the teeth, & was bumping last time I mowed. Now, won't turn at all.
There is a spacer/bushing on the very bottom of the steering column. With wear the bushing fails and lets the steering column/and gear on the bottom of it slip down to the point that the gears don't mesh. Replace the Bushing.
Sep 14, 2015 | Cub Cadet 46" Lawnmower Deck Drive Belt...
WHERE CAN I GET INSTRUCTIONS FOR CHANGEING THE DRIVE BELTS ON MY TROYBILT SUPER BRONCO?
is this the model you need?
http://www.troybilt.com/wcpics/TroyBiltUS/en_US/wwcm/769-03532.pdf
Aug 18, 2013 | Garden
Cub cadet lawn mower steering wheel will not turn all the way to the right. It turns all the way to the left, but not the right. Checked the teeth on the fan gear, all are okay. what next?
Even though the teeth on the fan gear are ok, they may have skipped past each other a few teeth. My tractor has a bushing that the end of the steering rod passed through before attaching to the fan gear. The bearing was worn, allowing the steering rod to move, and the fan gear would then to lose it's grip from time to time, eventually making my tractor perform much like yours. See if you can replace that bushing, your issue should be solved.
Mar 17, 2013 | Cub Cadet 50 In RZT Deck Belt 75404044
Cub Cadet steering problem
If there is not excessive play in the steering it could be the differential is not functioning properly. The differential is what makes the drive wheel on the outside of a turn drive more than the wheel on the inside of the turn. If you can make super tight right hand turns all the time but lefties are an effort despite the steering wheels being almost or all the way to the stops have the transaxle checked.
Sep 19, 2012 | Cub Cadet Garden
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
The steering on my Husquavana 150 mower is slack and uneven, it turns sharp to left but not to right. Gear wheel at end of steering shaft is worn. How do I repair it with more sustainable solution. Thank...
replace steering gear and lower nyliner bushings on steering shaft. Also check sector gear for wear and replace if needed. When replacing gear place front wheels straight forward and center steering wheel-the unit should steer the same both ways then.
Nov 22, 2009 | Husqvarna Garden
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit...
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Jul 27, 2009 | Garden
Garden Logo
137 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
