Question about Fantom Computers & Internet
The indicator light flashed as normal, then went steady light as normal, but then unit turned off about one second later. tried to restart it several times with the same results, then the indicator light no longer lights up at all.. I'm not sure which model we have, but the serial number is 322257. There is this other number as well TFDC25072. Important time sensitive files that I currently need to access. Please advise. Jay Williams jwdc@jwdc.com 11919 Franklin St. Beltsville, MD 20705 301-937-8633
MikeNJ1964
  • 398 Answers
SOURCE: Loud bang, unit stopped working
I have seen the caps in the power supply vent, which means they get hot and the top pops up and splits open, resulting in the "bang" sound. If you have experience in electronics then remove the back of the set and examine the power supply, looking for any caps whose tops are bowed upward, and replace.
Posted on Jun 28, 2007
djnick989
  • 1067 Answers
SOURCE: Green light flashes 7 times on power-up then turns red (off).
ya thers class action law suit on that bulb your talking about it will go out after 3 mo pp say its reall bad
http://www.consumeraffairs.com/home_electronics/panasonic_lcd_tv.html
I read in the various forums that frequent lamp failure can be caused by a defective ballast. I have not seen the schematices for the TV but typically a ballast controls current flow in a lamp. If I understand your post correctly it sounds like you have had a lamp failure per month for three months. I would recommend that you contact Panasonic 800-211-7262 and see what they propose. I think there is a design flaw with this model and they may be taking care of the problem. I would expect that a repair to the ballast would be a shop repair. Please post what response you get from Panasonic.
call them alot pp say they give u free one cuse they knw better ok
Posted on Jan 22, 2008
SOURCE: Blinking Lights
The problem was with the power source not the actual drive so I ended up pulling the drive out of the case and purchasing a new case from Newegg.com. It now works fine and only cost about $30 to fix.
Posted on Mar 23, 2008
SOURCE: My SImpletech 320gb external harddrive won't turn on.
I had a problem with my 320g Simpletech not showing up on my computer, I would plug the power supply in and connect the usb cable, the blue light would flash for a moment then nada. I found out I was using the wrong power adapter, you have to use the one that came with your simpletech, it is easy to mix adapters up if you have a few laying around.
Posted on Jun 13, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Posted on Jul 08, 2008
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Jan 31, 2015 | Panasonic Heating & Cooling
Is the red flashing light on evaporator circuit board normal.
some units just shine steady others steady blink as normal,,the trick is does it blink a number of times then pause this indicates a code. some will display multiple codes at one time, generally there is a sticker on the access panel inside or out with a listing of codes. thank you and hope this answers your question, most units have safety proticalls to prevent the unit from working under dangerous conditions
Feb 03, 2011 | Heating & Cooling
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Projector lamp flashes and the temp red led lights.
Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
Computers & Internet Logo
205 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
