Question about Legacy 2CH 1000W AMP Car Audio Amplifier
How do i wire up my amplifer into my car - Legacy 2CH 1000W AMP Car Audio Amplifier
  • 3 Answers
Cable to battery, cable to ground(in the trunk somewhere. rca cables and remote wire from the back of the car stereo.
Posted on Aug 04, 2010
2002pathfinder fan control amplifer blows out after working 15 minutes
Control modules are very sensitive to poor grounds, it causes the current to ground through compnents and damage them. Get a wiring diagram find the grounds and repair them first.
Jan 02, 2015 | Cars & Trucks
Subwoofers causing amp to go into protection mode?
This can be speaker wires touching, poorly grounded amplifier, battery power is too little for amplifer or speakers wired below minimum amplifer impedance.
Sep 20, 2013 | Car Audio & Video
I have a 2006 cadillac escalade and my speakers went out, they come back on every so often but they stay out for the most part.........i'm thinking it's amplifier.....need some help, what can i do
If you can finder your amplifer check the connections for your wiring. You could jus have a bad ground wire that has a weak connection or a hot wire going to your amplifer that has a bad connection aswell. If it is a bad connection then when you hit bumps going down the road is probably causing them to come on and off without your control.
Sep 07, 2011 | 2006 Cadillac Escalade
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
The radio and the cd turns on but no sound comes out after having the battery replaced. The vehicle is a 05 Mercury Mariner
radio runs off two power wires, one full time power and one switched power check to see which is working. turn the key to acc. and see if power stays on with car off, check all fuses. open the hood and look at battery cables, look to see if everything was hooked up right and if there is a amplifer in your car could be a fuse on the line to the amp either next to the battery or next to the amplifer.
Feb 15, 2010 | 2005 Mercury Mariner
I got two DUAL 2omn speakers and i just need to know best way to wire them for a mono block amp. i have them wired parrallel in the box
With 2 speakers wired in parallel, the impedance will be halved, so you are presenting a 1 ohm load to your amp.
Many amps can drive a 1 ohm load, but not all of them. Check the specs for your amp.
If it can't drive a 1 ohm, then you'll need to rewire them in series. 2 speakers wired in series will double the impedance, so you'll present a 4 ohm load when they're wired that way.
Jan 29, 2010 | Kicker (2) S12L7 12in Solo-Baric L7 + (1)...
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
No sound coming from my speakers
If Theres No Sound Comeing From Your Speakers At All Fully Check Your Wires For Any Breaks Or Connectivity Problems To The Head Set Or Power Supply Also Check Your Fuses If Problem Persists Let Me Know With What You Looked At And Ill Try To Talk Your Through. Hope This Is Of Some Help To you
May 10, 2009 | Car Audio & Video
Location of remote amplifer wire
Get a DMM (Digital Multi Meter) and test the wires behind the factory radio one by one looking for 12+ volts when u power the radio on and 0 volts when u power it off. This will be your remote wire.
Jul 18, 2008 | Car Audio & Video
Legacy 2CH 1000W AMP Car Audio Amplifier Logo
43 people viewed this question
Top Legacy Car Audio & Video Experts
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
