Question about John Deere Turbo Combine 6602 7700 Harvester 5200 5400 ()
How to set the concave - John Deere Turbo Combine 6602 7700 Harvester 5200 5400 ()
I don't know what concave means
The curve of a lens is either convex or concave, that causes light to be focused depending on the direction of the curve.
So to answer your question, concave is just a bulging 'out' shape.
Feb 19, 2014 | Concave Lumbar Support-A6000
Picture appears concave and doubled
Most likely scenario is that the auto convergence option has disappeared which will cause the set to have an arced picture with double images. You can get the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with instructions.
Jul 31, 2010 | RCA HD52W56 52" Rear Projection HDTV
What makes a rip cut on the table saw to end up concave instead of perfectly straight? Does that mean the rip fence is concave from end to end too?
It is doubtful that the fence is concave but this can be checked with a straight-edge. More likely this is caused by the blade having hit a nail on one side and the teeth on that side of the blade are damaged. Hope this helps you.
Oct 18, 2009 | Saws
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
CRT display got concave!
This is a 'pin-cushion' effect caused by components failing in the set.
Apr 11, 2009 | Televison & Video
Viewsonic E70f,concave picture
Problem related to pincussion correction circuit.Normally dry solder near horizontal output / EHt section.
Feb 15, 2008 | Computers & Internet
Led display
Go into the monitor menu settings and adjust it.
Dec 25, 2007 | Computers & Internet
Sony KP-53XBR45: Concave Picture
try a system reset
turn tv off,
on the remote
display, 5, vol+, power
when set turns on press 8 then enter.
tv will turn off, then press tv on turn turn back on.  See if this helps
Sep 25, 2007 | Sony KP-53XBR45 53" Rear Projection...
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
John Deere Turbo Combine 6602 7700 Harvester 5200 5400 () Logo
56 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
