Question about Dryers
I have an ASL70C Ariston tumble drier that suddenly has stopped emptying the water into the water tray.the clothes are still drying but where is the water going
  • 37 Answers
Einy Lane -- Water Drain question -- If your dryer is installed next to a drain the water can be plumbed into this drain. This does away with the need to empty the water container. Simply remove the top hose from its top fitting at the rear of the dryer and plumb the hose provided to the drain.
If a leak has developed in absence of using the drain hose feature, then the water is going someplace else. Unplug unit and then check behind it for the drain line being fallen down. If you need more help, please write back. User Manual can be downloaded without charge from Hotpoint website. -- SWT
Posted on Aug 04, 2010
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
I want to know that on my washing machine lg-80BKF21P model the time(min) 10 minutes was remaining and the washing process is done,it ends but after drying all is done but 10 minutes were remaining and...
tumble driers and combination washer driers have a 10 minute safety margin, where the heat fior drying is dispersed, to avoid people grabbing very hot clothing.. especially if it is not quite dry as this would make them, hotter to the touch.
Tumble driers usually continue to tumble, but blow cool air through the clothes to get rid of the heat, before stopping.
Oct 02, 2017 | LG Washing Machines
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
Heating problem with Dryer Ariston ASL 70C
hi.
in top of the heater box there is a thermoswits back of this swicth there is a tiny little hole use a paperclip or similar an put it to the hole and press not to much until you hear a little click and the thermoswicth is reset. and your dryer can heat again:-) and DONT forget unplug the power to the dryer first.....
best regards
ls danemark.
Jan 30, 2010 | Hotpoint Dryers
Tumble dryer isn't woking
You may need to replace the thermostat or the heating element.
Apr 13, 2009 | Hotpoint -Ariston Aquarius WD645 Front...
My tumble drier dont heat up. It works but its
there will be a red overheat switch on the rear on most models, simply pull the machine out and press reset, the most cpmmon cause is running when empty or a build up of lint. if the doesnt work then it will be an open circuit element.
Apr 13, 2009 | Dryers
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Creda tumble dryer
It is probably the electric heater coil. How old is the machine? If a couple of years or more, the coil is probably burnt out. It is accessible through the back. Good luck!
Feb 08, 2008 | GE DBL333EA Electric Dryer
Dryers Logo
216 people viewed this question
Top Dryers Experts
Marvin
Marvin
