Question about Blenders
Re Oster Blender: How do you remove the coupling from the motor shaft? How do you remove the stud drive from the coupling? They appear to be frozen in place.. .
  • 2,272 Answers
You have to hold the armature so it will not move. Sometimes you can get lucky if you place something small into the fins on the fan from the bottom. Then turn the stud from the top. If it comes loose you are one of the lucky ones. Usually the nut that holds the fan onto the shaft just unscrews. If this approach does not work, you will have to cut the washer around the stud and remove the whole motor from the bottom. Taking the lower housing off of the motor, you should be able to hold the armature with a vise grips but be sure to use a cloth around the armature so you do not damage the shaft. Then turn the stud off.
The stud is screwed into a rubber coupling and the coupling onto the shaft.
To remove the coupling, you do have to take off the bottom of the housing (three or four Philips screws, depending on the model of blender). At the bottom of the shaft, there is a nut holding on the fan. Gripping that nut with one pair of pliers, unscrew the coupling with another pair of pliers. (The coupling sticks out of the upper housing far enough to get a grip on it). three philips screws on the bottom. When the bottom is off you should be able to hold the fan and twist the square drive and cover off the top of the coupler. You can now see the top of the old coupler.
Then you will see four hex head screws (the ones with big black tops that look like washers) inside required to remove the motor. Once you have the motor off you "should" be able to hold the cooling fan on the bottom while you twist the rubber coupling off.
Then replace and reassemble, screwing the square drive pin and cover into the other end of the coupler after you have the motor back in the body.
--------- When you remove the base of the blender (using a 1/4" socket wrench or nut driver inside the four rubber feet), you should see the big metal fan covering a big motor assembly. The fan is screwed on one side of the motor shaft, the rubber coupler and drive pin onto the other. How much of the motor assembly you have to take apart depends on how much of the drive pin / rubber coupler is left.
Looking at the top of the unit again, try to get a pair of Vise-Grips clamped solidly to the rubber coupler (or what's left of it). If your vise-grips are too chunky to reach inside the blender housing, you'll have to do more dissassembly.
Get a 4" extension attachment for your 1/4" socket wrench. Look deep inside the blender, and you'll see four bolts holding the motor onto the housing. They should be slathered in grease. Being sure not to lose any washers, rubber gaskets, or other parts, Unscrew all four bolts and slide the motor assembly out of the housing.
Now you can see both ends of the motor - the drive end and the fan end. Clamp the motor's square solid magnet frame into a vise, so you can work freely. Take the fan off - notice that the threads have a flat spot ground onto them to keep the fan aligned. VERY CAREFULLY clamp a vise-grip onto the flat part of the fan-side motor shaft, using a thin piece of wood, folded rag, etc. to protect the threads on the non-flat side. Get this good and tight, but don't dent the threads.
Now, clamp another pair of vise-grips onto what's left of the drive pin/rubber coupler, and spin counterclockwise to loosen.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 04, 2010
The drive stud on my vitamix 3600 blender sheared off. When screw is replaced it comes unscrewed when the blender is turned on. Does anyone know if the original design included epoxy weld?
If the motor runs in reverse to an Oster which uses counter clockwise thread then it follows that your thread should not be counter clockwise. If it comes loose when you turn it on surely the thread on the coupling must be faulty because according to your description the action of turning it on can only be to tighten the coupling. Most couplings with a thread that I have seen are counter clockwise so you will probably struggle to find another brand coupling to match.
Feb 28, 2015 | Vitamix Blenders
How to fix the blender,the motor works ok but the blades don't move
check to make sure the drive stud is spinning with the motor. If it is, make sure the blade assembly is lining up correctly as well as fitting tight on the drive stud. How to Repair Blender How to Repair Small Appliances Tips and Guidelines
Dec 09, 2014 | Oster Blenders
Remove stud drive from blender
You have to use a flat edge screw driver for locking the motor shaft.
first you put the screw driver to the slit on the motor shaft at at the bottom side at the same time you should use suitable wrench for unscrewing the stud
I hope this helps
Mar 30, 2013 | Waring 502696 Drive Stud
How replace Drive Stud & Slinger Pin part
No need to:
- cut the washer or
- remove motor
Hold washer w/ vice grips and turn stud counter clockwise with box end wrench, small crescent wrench, or another vice grip. Should turn fairly easily at first then finger loosen. A 50y/o model 541 continuously exposed to salt sea air gave no resistance at all w/ this method.
Aug 02, 2011 | Oster 006832000000 10Speed Blender
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Replacing the part that connects the motor to the blades on an Oster blender
I don't know if this will help or if this is what you are looking for. But today I was searching the web for the bottom piece that fits on the jar and saw this website has a lot of replacement parts for Oster blenders. Hope this is what you're looking for.
Good Luck
http://www.goodmans.net/get_item_os-070_square-drive-pin-for-oster-osterizer-blenders-shor.htm
Sep 12, 2008 | Oster 6803 14 Speed Blender
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
Blenders Logo
760 people viewed this question
Top Blenders Experts
eyecam
Marvin
Marvin
Are you a Blender Expert? Answer questions, earn points and help others
