Question about AEG Washing Machines
Washing machine - efo error display. machine stops. bleeping sound
  • 269 Answers
The code EFO shown to the user can either be related to a blockage in the filter or pump.Also check the outlet drain hose for kinks or blockages.Another one to check out is that there is not too much detergent in the drum as this causes overfoaming.
Hope this was helpful.
Posted on Aug 04, 2010
HI, The machine displays "EFO"... We put the water out as described on your site but it seems the code "EFO" is still in memory (there is no more water inside, but each time we start a new program, the...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 15, 2010 | AEG Lavamat 88840 Front Load Washer
Efo
Hello,the EFO code is a general error that is caused because of 2 things:
1.Use of too much soap can be one of the cause of the error. to clear it run the machine through a quick cycle or normal cycle but without using the soap which will drain out the excess soap.
2. The other reason could be that the drain pipe is clogged , to clear it you can remove the back cover of the pump an remove the hose. Inspect them and clean them if nay obstruction.
Thanks
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
May 15, 2009 | Kenmore 44102 Front Load Washer
EFO, E10 error Message
Feb 09, 2009 | Frigidaire GLTF2940E Front Load Washer
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning...
Dec 15, 2008 | Frigidaire Washing Machines
Beep with a display saying EFO
Dear novscorp,
According to the error code chart (a loose insert included with the operating instructions) EF0 means two things: Error 1. Over sudsing  or  Error 2. Hot water does not enter.
For over sudsing, it lists the possible causes as: a high efficiency detergent was not used (the detergent brand will have "he" on it for high efficiency) or too much detergent was added.  The solution lists: Use only a high efficiency detergent.  Follow manufacturer's recommendation for dosage.  Amount may need to be adjusted for water temperature, water hardness, load size and soil level.
For the 2nd error, hot water does not enter, it lists the possible causes as hot water hose is connected to the wrong faucet or hot water faucet is not turned on.  The solution lists: Connect hot water hose to hot water faucet and hot inlet on washer.  Be sure hot water facet is fully opened.
On a personal note, I received the same error when I mixed my detergent directly in with my color safe bleach.  It just caused a lot of suds in the machine.  One rinse cycle solved it.
Hope this helps, Ellenk4
Aug 18, 2008 | Kenmore Energy Star 44092 Front Load...
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
ERROR CODE EFO
You can call or email the manufacture to find out.
May 27, 2008 | Frigidaire GLTF2940WH
Err code e10
it sounds like your brushes are gone you need new brushes in the motor
Dec 18, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
1,380 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
