Question about Armitron Watches
Cannot get back plate to go on - Armitron Watches
  • 831 Answers
You will need a back press. Take to local jeweler who should have one.
Posted on Aug 05, 2010
There are 6 small grooves around the back plate of my fossil AM3996, is there a certain tool ,that when used with these grooves, removes the plate, or are they cosmetic?
Certainly the grooves are not cosmetic. These are meant for removing the back plate for which there is a special tool to turn it anti-clock wise to open.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Nov 11, 2011 | Fossil AM3727 Wrist Watch for Men
I'm looking for the worth of a ladies Bulova watch with 10K Rolled Gold Plate L3 1131948 on the back.
i have a bulova same no. speidel pat. but the serial no. u lookin is different this one is 10kt rolled gold plate back.
Oct 20, 2011 | Watches
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 | Watches
Water inside
you need to open the back plate of your watch and sit the watch in a dry warm area for atleast 24 hours to allow the water to evaporate and dry out..to open the back If the back plate of your watch is smooth around the edges, then it will pry off. Look carefully around the edges for a spot with a small gap, which it may or may not have. Prying gently with the tip of a sharp knife, usually with a light twisting motion, will pop the back plate off the watch. It simply presses back into place with moderate-to-light pressure. IF the back plate has notches around the edge, it need to be unscrewed from the back. Harbor Freight has a cheap tool to engage these notches and turn the plate, but I've had good luck simply using the tips of a needle-nose pliers to engage these notches and unscrew the plate.
Jun 19, 2011 | Chase Burberry Endurance BU7503, Steel...
The word (op en) on the top in place of the date or the day and nothing is responding
I had this problem and managed to fix it. There is a small metal plate locate inside the back cover of the phone that can be knocked out of position. The small plate should be in contact with the two screws in the top right hand side of the watch (when back plate is off).
To remove back plate you must remove the strap. To do this you must remove the four pins that connect the strap to the watch body. Take out the pins and set aside. The two plastic inserts can now be removed.
Remove the four screws and remove the back plate. Be careful not to lose screws, rubber seal and small plate.
Reglue the small plate to back plate and allow to set.
Reassemble watch in reverse order and watch should work as normal.
Good luck
Feb 27, 2011 | Casio Protrek Triple Sensor PRG70 1BVDR...
Battery replacement
Hi.
Battery replacement is done removing the back plate. The back plate is uncrewed clasping it with a special tools and rotating anti-clockwise. In absence of the special tool a common pair of tweezers will do the job.
Once the back plate is off, extreme care must be taken with the rubber seal, running around the edge of the case opening. This is very delicate, and damaging or kinking the seal may result in the watch loosing its water proof capacity. For this reason battery replacement is better done at the shop.
Here casio page for this model:AMW320R-
Sep 28, 2010 | Casio AMW320R 1EV Casual Sports Watch
Battery replacement procedure for Casio 901 DW-5600?
hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
What do you use to snap on the back plate of a wristwatch
Tools are available from many watch suppliers, one is Jules Borel, jborel.com, best to get a new gasket and mabey a spare if you wear this in the water then a new crown or crown seal also.
Jun 11, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Watches Logo
21 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Bill Boyd
Are you an Armitron Watch Expert? Answer questions, earn points and help others
