Question about HP Pavilion dv6000z Notebook
I cannot find the wep key for my computer. Where can i find it?
    Sergeant:
    Champion:
  • 301 Answers
The key is in to router , give me the model and i can to say how you can see the key modeln and brand router
Posted on Aug 04, 2010
    Guru:
  • 1,082 Answers
This is set in the router. Log on to it and eliminate security or push the reset button on the back to restore factory defaults. This will also reset the SSID for your network.
Now test to see if you can connect. If so, set up WPA if it is available, else WEP.
Am trying to add kodak wifi printer to my laptop, how do i find wep key and wpa
I was having the same problem with my computer in reference to finding the wep key through the router. My setting were changed on my computer at work and then the computer would no longer work on my home network. I had to find the wep key.
1.) using the internet explorer (not AOl or MSN or..)but the internet explorer that your computer came with.
2.) enter "192.168.1.1" in the website address field. do NOT use www in front.
3.) this will bring you to a linksys website.
4.) click on wireless
5.) then wireless security
6.) then you will see the page with the wep key listed.
7.) use the first wep key listed.
thought this might help you
Mar 17, 2011 | Computers & Internet
How doi find my wep key?
Your WEP key is the key for your wireless (wifi) router. You will need to check the settings of your specific router in order to access the WEP key settings. Your computers on the wireless network have the WEP key too, but it is like a password and cannot be read from the computers, it is only found on the router setup/settings.
May 07, 2010 | Sony Playstation 3 (PS3) Console
How do you locate wep key for comtrend ct-5361t router
To find out the WEP key, you will need to access the routerset up. Do you have any computer connected to the router Or any computer online using the same router ? If you do not have any computer online through the router then you will need to connect the computer to the router and access the routerset up. Once you access the router set up then you will be able to locate the WEP key. Click Here for step by step solutions
Nov 17, 2009 | Computers & Internet
What is the WEP key
Wired Equivalent Privacy (WEP)
WEP is an older network security method that's still available to support older devices, but it's no longer recommended. When you enable WEP, you set up a network security key. This key encrypts the information that one computer sends to another computer across your network. However, WEP security is relatively easy to crack. f4008eb.jpg
Nov 16, 2009 | NetGear WGR614 Wireless Router
Can't find security key
the wep/security key on 2 wire modems is located below the serial number label on the side of the modem.
Sep 25, 2009 | 2wire 2700HG-B Router (2700HGB)
How do i get my wep key
Option1:
You can find the WEP key of your Wireless network after login to the Router. The WEP key is saved in the Router. Check the User Guide of the Router for the instruction to login to your Router.
Option 2:
If you are using a Computer with your wireless network and if the Wireless Key (WEP key) is saved in the Computer than you can use any application like "Wireless Key Viewer" or SIW for view the saved WEP key in the Computer.
Good Luck!!!!!!!!!!!!!!!!!!!!!
Sep 21, 2009 | Computers & Internet
How do I find my wep key as I need this to connect my printer to my router in order to use this on my network
Option1:
You can find the WEP key of your Wireless networl after login to the Router. The WEP key is saved in the Router.
Option 2:
If you are using a Computer with your wireless network and if the Wirelees Key (WEP key) is saved in the Computer than you can use any application like "Wireless Key Viewer" or SIW for view the saved WEP key in the Computer.
Sep 15, 2009 | HP DesignJet T3100PS Clr Inkjet 44"...
I am connected with a wireless network but i can not access the internet in says secure certificate.. what is the best thing to do
This sounds like you have wep security enabled and don't have the correct wep key programmed. Check your router to see if it is set to require a WEP key, if it is select the option to show you characters for the key then look at your computer netwrok settings and ensure that the same WEP key is being provided by your computer when it logs into the router. This should solve the problem. You can also get the WEP key information from your service provider if they installed the wep key remotely which is a common practice.
Sep 08, 2009 | Computers & Internet
Wep key data of nokia 9300i
Hi..
Let me help you out..
You have to enter WEP key which you used for computer synchronization.
Let me know the Router Model you are using..
follow this steps:
Option:1 - If setup with Bluetooth or Router with Mobile.
Just enter 12345
if it promts again in the computer there also enter 12345. use same key in all places when it prompts.
Option:2
If the setup as Router computer and Cellphone.
1.Open Router Configuration page by accessing default IP address mentioned on the router.
2.Go to Security or WEP tab. disable WEP.
or set WEP key
3.now enter the same Key for your nokia 9300i.
Feb 17, 2009 | Nokia 9300i Cellular Phone
HP Pavilion dv6000z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
