Question about Honda Garden
Which type of oil do I use for my Honda G200 5.5hp petrol pressure washer engine? Many Thanks, Paul.
  • 21 Answers
Straight 30 weight oil
Posted on Aug 29, 2010
Testimonial: "Many thanks."
Homelite power washer too much oil
Hi Martin, check the level of the oil in the engine, if the level is low, the machine has been tipped on the side and the oil has gone over the head. Make shore that engine is on the flat ground when used or transported. Tilting the unit over 20 degrees will cause the oil to go over the head. Two ways to fix the problem pour some petrol in the cylinder, put a rag on the spark plug hole and pull the starter rope few times to clean the cylinder, repeat the same until the cylinder is clean. You have to check the carbi for oil getting into it, and clean it. Make sure you clean all the petrol before attempting to start the engine. It is a bit messy but not require to pull the engine apart. The other way to clean the oil is to remove the cylinder head off and clean it, its the proper way of doing the job, but requires a lot of dismantling. Hope this helps. Cheers
May 19, 2014 | Honda Pressure Washer PSI 3000
WHAT OIL SHOULD I USE FOR THE HONDA BM80913A PRESSURE WASHER . I HAVE OIL FOR 2 CYCLE ENGINES BUT I AM NOT SURE IF I CAN USE IT. I do not have the service manual available
If you are asking about the oil for the gasoline engine then you can use a 30 weight engine oil like you would use in a car engine. Pressure washer pumps use a special non-detergent oil which is not the same as the engine uses.
Jul 16, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
What type of oil is needed for a Honda GC160 Power Washer? Honda 2500 PSI x 2.3 GPM.
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
May 27, 2010 | Honda Pressure Washer PSI 3000
Miller falls pressure washer pw2hp seized
hi there is a black screw at the bottom of the engine (plastic) if you remove this it is a dip stick. i would also remove the pump from the enging to see if its the engine,gearbox,or pump at fault hope this helps you. any more problems just reply back and i will try to answer your questions regards
Jan 16, 2010 | Honda Pressure Washer PSI 3000
Timing a 13 hp GX 390 Honda engine
I believe it is either one but if you are not sure, stick a screw driver in an see if it comes out with oil on it. Does one not have an oil level stick attached to the cap?
Jun 18, 2009 | Honda Pressure Washer PSI 3000
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
799 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
