Question about Marshall MG100HDFX 100-Watt Amplifier Head
GM100HDFX head. Fuse blows immediately upon power up when output module on fan-cooled heat sink is plugged in. Increase the fuse and loud buzz comes out through the speaker. No volume control then. Unplug the module with original fuse and headphone output sounds fine for use as line out. Replaced module on fan-cooled heat sink and same thing happens. Symptoms are repeatable. No apparent damage from troubleshooting this way. Used Arctic Silver thermal paste on module instead of white type. Powered off immediately upon buzzing. End of testing. Can you help? My vocabulary of these parts is lacking so please be descriptive... diagrams/pics/arrows? Thank you.
  • Marshall Master
  • 5,603 Answers
NEVER increase or replace the fuse without repairing the unit. Further damage is likely if you do so.
Put a light bulb, say 150 watts in series with the power to the unit to act as a fuse that won't damage things while troubleshooting. The light will light and limit the current.
There are three 47mfd/63V electrolytics on the output module. I suspect one of those is shorted. Observe the correct polarity when replacing. C2 and C3 are most likely. Use my above suggestion with the light bulb and check the voltage across each of these. It should likely be in the 35 to 45 volt range though schematic doesn't show the value..
Posted on Aug 06, 2010
Why does fuse blow when unit is powered up
I rather suspect IC1 TDA7293 is the cause of your problem. If this is the case you will need to check the speaker/s
Nov 12, 2014 | Marshall Amplification Marshall MG250DFX...
Amp has power ,is getting signal , meter moves when I hit the strings of the bass. but no sound coming out of either cab. ran a line out and it works that way ,
Looks like the power module went out, could be either LM3886T Power IC or Mosfet Module But certainly is in the output stage where your problem is, hope this helps to troubleshoot the issue at least...
Nov 03, 2013 | Behringer Bx4500h Ultrabass 450w Bass...
Why my Marshall amplifier immediately blows fuses?
It could be a failed power supply capacitor, it could be a shorted speaker, it could be a shorted cable. It might also be a conductive piece of trash in just the wrong spot on the circuit. They would be the big ones of about 5000 microfarad give or take a few hundred microfarads.
Though a little less likely, there could be a short of failed component in the output stage.of the amp.
Sep 25, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
I got a Marshall MG100HDFX for free from a friend stating it was blown. I asked how this happened and he said that one of his friends plugged in another speaker or amp into the second speaker input in the...
The power amp section has blown parts. You will likely find they use a chip like the TDA7293 as the power amp output and it will be blown, shorted causing the fuse to blow. These cost $6 from Digikey.com. Find a competent tech to replace it and use heat sink compound. Verify the part before ordering one. They come with leads bent either way so make sure you get the one with a matching suffix letter. When firing up after repair, put a 60 watt light bulb in series with the hot power lead to act as a current limiter... saves blowing fuses if there is another problem.
Jun 21, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
MY ALESIS DM5 WAS PLUGGED TO 220V AND AFTER A WHILE STOP WORKING ( IT IS FOR 110 V ) IS ANY FUSE I CAN REPLACE?
Hi pcruzx,
Sometimes replacing the fuse alone with exact voltage and ampere ratings will cure the problem(you're lucky) but not all. Sometimes further damaged gone to other parts most especially the voltage regulator transistor/IC (mounted in heat sink) and the opened the fusible resistor in line with the supply(B+).
First check the fuse, for sure it was already blown. If you've replaced the fuse and immediately blew again after powering on the unit, this was an indication of shorted parts near the AC line. Click this LINK for more info.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 01, 2011 | Alesis Dm5 Drum Module 18 Bit
Marshall MG100HDFX Amplifier Head does not turn on
If you connected both speaker outputs of the two heads together you likely destroyed the output transistors of one or both heads. assuming they are solid state. It is unlikely a tube amp would have much damage.
The sequence would be that when you started driving the second unit, the feedback paths within it would fight the attempt to drive backwards and the output transistors would first overheat and then short, This would put a shoirt on the power supply and blow the fuse. The damage would be permanent and would LIKELY NOT include the transformer.
Expect the power transistors, driver transistors, associated resistors to go up in smoke. The unit will have to go to a shop to repair. Probably $30 of parts wholesale, but labor is going to cost you for sure. Expensive mistake.
Refurbing this has to be done carefully to insure all bad parts are replaced as a single bad one left in can blow the whole lot again.
The new Speakon connections avoid some of these mistakes... but not all.
Operate ALL you equipment from a single point source of power to avoid ground loop and faults from causing "common mode" destruction of circuitry.
Mar 18, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Dear experts, i have a MG100HDFX and no sound seems to come out. i replaced the burnt fuse inside the head and i disconnected the timer for the cooling fan cuz thats what kept blowing the fuse. With the...
The problem is not likely to be the fan. I would suspect the output section of the amp to have a problem. These units use a 15 leg power IC for the output. Look for a small IC attached to the heatsink. It will be marked TDA7293V. This is the likely defective part.
Dan
Jan 07, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Blows main fuse. Found burnt place on circuit board where connection 1 is. It's the board that's mounted to the heat sink with fan at the back. Disconnected connector 3 that goes to con 1. Now fuse does...
Chances are a power transistor has shorted. Sometimes input rectifier diodes short or electrolytic caps.
Here is a hint to troubleshoot this: Connect a 150 watt lamp in series with the hot side of the power line to the amp. This will limit the current (and voltage) and prevent the fuse from blowing. You can do a lot of troubleshooting at the much reduced voltage.
If board is burnt to carbon, this "cancer" needs to be cut out and removed as the blackened board is slightly conducive instead of an insulator. Often a circuit trace has fried the board. One must install jumpers around ones that have smoked.
Sep 24, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Loud speaker hum then blows fuse
Hi there. The final output IC (big and black with 15 pins? attached to heat sink) is shorted and needs to be replaced. If you can still see color bands on R63, it should still be good.
Thanks
Paul
Jul 12, 2009 | Music
Cooling fan ,heat sink MG100HDFX does fan blow out or **** cool air in? Someone left it unassembled..
If you can get two IN then do it but make sure one is pushing air out and the other sucking in.
Feb 01, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head Logo
217 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
