Question about Dryers
The dryer "lintfilter" light comes on and the dryer stops- however the lint filter is totaly clean and free from lint. how do I fix this? Sue
  • 37 Answers
Sue -- LINTFILTER light without visible LINT means that either A: the internal (or exhaust) lint pathway is blocked or B: the sensor that makes sure the unit does not "overheat" is malfunctioned. Check the dryer output hose to make sure it is not plugged. Get your vacuum cleaner and make sure there is no lint buildup below the lintfilter screen. If you need more help, please ask. -- SWT
Posted on Aug 04, 2010
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Warning signal "linter filter" comes on and dryer
You don't have very much information here to give you a better diagnosis, like the model or the error code, but I'll take a shot at it. If you're thinking that the flashing list filter light is the error code you can relax. The lint filter light ALWAYS flashes at the end of a cycle or before you hit the start button to begin a cycle. This is just a reminder to check the filter.
If your dyer is displaying an E:01 code this indicates blockage in the venting system. Do the simple thing 1st. wash your lint filter with some dish soap and running water, lightly scrubbing it with your finger tips. After rinsing clean pat the filter dry and re install it in the dryer. While you have the filter out look down in the filter holder area and see if you have lint built up there. They make brushes for cleaning this area or you can use a vacuum cleaner attachment to reach in there and **** out the lint.
If you still have an E:01 error after doing all this you may need to have your house vent pipe cleaned. But before you do this check your vent hood where the dyer vent exhausts out of the house. If it's obstructed you found your problem
Nov 27, 2010 | Bosch Nexxt 500 Dryer
I have a kenmoore stack washer and dryer, the dryer was running and stopped it and took clothes out and about 10 min later after I stopped it I heard the buzzer go off and smoke was coming out of it. I...
When you have smoke coming from a dryer, the most likely cause is lint on the element. Clean the element, clean the lint trap filter, (AFTER EACH AND EVERY LOAD), and make sure your vent is clear, free from lint and moisture.
Oct 05, 2009 | Dryers
Maytag atlantis dryer exsess builup lint
What product have you purchased from this site? We are a collection of knowledgeable people who are not afilliated with any manufacture. While you have the OPTION of paying to work with someone live, if you leave your information posted for a day or two, one of us will generally get back to you with some FREE help.
Now on to your problem. While I don't know what model of maytag atlantis you have, these are the general guidelines for cleaning out under the lint screen area. The easiest approach is to buy a vaccume extension availible from appliance parts stores and some hardware stores. I have even seen a clean out kit for sale at bed, bath and beyond. Basically you fit the vaccume extension on to the end of you vaccume and feed it down to the area under the lint screen. To do a more efficent cleaning you would need to dis-assmble your dryer. If you can supply the model number located just inside the door, I could get you a step by step tear down to get to it from the inside.
Jul 05, 2008 | Dryers
Keep getting 3 beeps and the lights come on while its beeping.
Mine has been beeping incessantly as well. Turned out that even though I was cleaning the filter after each load, there was still a ball of lint the size of a tennis ball that was blocking the lint sensor. To fix, I removed the screws from the plastic piece that holds the lint trap and slid it out (it won't come out entirely.) Then I used the mini attachments for my vacuum to remove the lint from the bottom of that space. Once I did that, the dryer has been working flawlessly.
Mar 24, 2008 | Frigidaire FEQ1442ES Electric Dryer
Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
173 people viewed this question
Top Dryers Experts
Marvin
Marvin
