Question about GPS
I purchased a garmin map for Florida and when i inserted it in my nuvi 250,the already installed map of Ireland UK and Europe was wiped. Also the voice command is no longer functioning. The Florida map worked well despite the lack of voice command Can I get the map back and the voice command. Thanks Gerry Wall
    Genius:
  • 1,478 Answers
I suggest you reset your GPS, to reset your gps, follow this steps, turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the Garmin GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 – 30 minutes in order for it to requires fix to GPS satellites. with this, this should fix the problem.
Take care.
Posted on Aug 04, 2010
I need to put a scotland map on my garmin.what do I do ?
The map of Scotland comes with the "UK and Ireland", "Western Europe" or "Europe" maps so if you buy any of the three you'll have the map of Scotland. You can buy one of the maps by going to www.garmin.com and logging into myGarmin. Click on the myMaps tab at the top of the screen and then on "Purchase more maps" Follow the prompts.
Before buying the map, if you have a satnav bought in the USA you need to check if it will work in Europe. Most of the USA garmin nuvis will not work in Europe with the exception of those that come with both European and American maps.
Jun 14, 2011 | Garmin GPS
Need to upgrade maps for ireland
The easiest way to do so is purchase mapping on a pre-loaded microSD/SD card and insert them into the unit. I recommend getting all of europe for the cost here is a link http://www.gpscity.ca/garmin-microsd-city-navigator-europe-nt-2011-card-with-adapter.html.
Hope this helps!
Mar 03, 2011 | Garmin nuvi 255W GPS Receiver
My garmin nuvi 205 is in american but i live in the uk how do i change it
If it's the map you want to change you'll need to buy the UK map. To do this you need to have it registered.
To register your garmin nuvi satnav connect it to your computer.
Go to www.garmin.com
Select your country from the drop-down list
Click on the myGarmin tab at the top of the page
Click on "Register your garmin device"
Select "automotive"
Follow the prompts
You'll be asked to create a username and password. Keep them safe as you'll need them if you need to update your maps later
When it's registered Log into your account.
This will bring you to a screen where you have the option to buy more maps. Buy UK and Ireland or Western Europe. Don't go for the complete map of Europe as it will not fit on your satnav. If you download the new map to your satnav it will overwrite the map already on it. If you want to save the American map you can install the new map to an SD card. You'll need to download it to your computer and then install it on the SD card. Details on how to do this are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
There's more information there than you'll need but it gives very detailed information on installing maps to an SD card.
To change the voice from American English to British English;
Press TOOLS (the spanner symbol)
Press SETTINGS (the spanner symbol) or LOCALE if there's not a settings icon on your satnav.
Press LANGUAGE (the lips icon)
Where you see VOICE press it and select a British voice.
Dec 18, 2010 | Garmin nuvi 255W GPS Receiver
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Question will Canadian Garmin work in Ireland?
It will work in Ireland but it'll need a map of Ireland which is on the maps of Europe, or Western Europe or Great Britain and Ireland
Aug 26, 2010 | Garmin nuvi 250W GPS Receiver
I bought Garmin nuvi 250 in Thailand and it works well. However, I brought it to London and try to use it.. It always show "unable to calculate route: no roads near starting point". Moreover, the screen...
It's possible that it doesn't have a map of England. Press Tools, then press Settings then press Map. Press Map Info. This will show you the maps installed on your satnav and the map selected should have a tick beside it. If there's no map of Europe or UK on it you'll need to buy one. If there's one there but not ticked press on it and it will become selected and should work fine then.
If you need to buy a map you'll need to register the satnav if you haven't already done so.
TO REGISTER
Connect the satnav to your computer and go to www.garmin.com. Select your country. Click on myGarmin and then on Register Your Garmin Device. Follow the prompts. You'll be asked to create a username and password. Keep them in a safe place as you'll probably need them again to update maps.
TO BUY NEW MAPS.
Log into myGarmin and click on myMaps.
Click on Shop fFor More Maps.
Select the one you want, UK and Ireland or W Europe would do. Follow the prompts.
Aug 19, 2010 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
I have a garmin nuvi 250 device and want to update the maps for the UK and Europe. I have been told this can be done for free, can someone please help?
oh man i don't like when people ask me for free but u know what i bet u are a great guy and i can help u.THE ONLY THINGS YOU'L NEED IS AN USB,GPS WITH FREE SPACE,AND GOOD FAST INET.
Open www.thepiratebay.com
and type in the search engine garmin nuvi 250 (map and version)
for example
garmin nuvi 250 europe 2.16
i don't think there is a map that is 2.16 but...
than download the one you want and type in keygen generator garmin 250 nuvi
and than download it when you downloaded all the data copy the map in your garmin drive
and copy the .meta file to the keygen file folder load/run the keygen and write your device code than copy the map code. than disconnect your device and then when your device asks you for the map code write the code that you just have copied
Apr 26, 2009 | Garmin nuvi 250W GPS Receiver
I want t travel accross europe and do not have full addresses to enter into my garmin nuvi 250 please could you tell me how to do this Lynn
The nuvi 270 is the model that comes with pre-loaded maps of europe. The nuvi 250 only has North America. You can find the right maps on Garmin at: https://buy.garmin.com/shop/buymaps.do
You can purchase all of europe or select areas which are $50 dollars cheaper.
Jan 20, 2009 | GPS
GPS Logo
23 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
