Question about Dell Dimension 3000 PC Desktop
My computer Cd/dvd drive doesn't work after a computer tech fixed my operating system. It crashed. The drive opens, but it does not show in device manager. Then opening a program it says no cd/dvd device found? bwoodgirl24@yahoo.com is my wifes email. Please email or cal me 321-652-4964
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
Check the jumper settings of your cd drive put in slave, if hard disk is in master , checkthe data cable or replace the data cable and check
Posted on Apr 28, 2008
Where is the button on the laptop to open the disk drive on my asus
I think you mean cd/dvd drive, not the "disk drive" which is the main storage device inside the computer and is only accessible by taking the computer apart. On my Asus, the button that opens the cd/dvd tray is on the tray, which is on the right side of the computer. If you can't find it or it doesn't work, you can open the tray by choosing "eject" on the file menu or "home" menu, or whatever shows the cd/dvd drive on your operating system (probably windows).
Oct 06, 2017 | ASUS Computers & Internet
I have msi laptop , my optiarc dvd Rw ad-7530b ata device doesn't work and not showing. when i go for update, it's give me error on registery. and i go for run i didn't find the folder li
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Feb 06, 2013 | Microsoft Windows Vista Ultimate Edition
Hi my computer doesn't see dvd/cd drives .When i pull it up in device manager it shows drives but they have a yellow exclamation point in front of drives what can i do . thanks hotrize
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Aug 18, 2011 | Microsoft Windows XP Professional
CD player will not work
Try a different CD. iIf the computer doesn't recognize it at all, listen for the drive to spin and look for a blinking light on the CD tray. These signs do not necessarily mean the CD drive isn't broken. I would find the model number of your laptop and do a search on eBay for a replacement CD drive. These are very easy to switch out. If the new one works, then you're set. If it doesn't work, there may be an issue with your motherboard.
May 07, 2011 | Toshiba Satellite Pro L300 Notebook
No system disk has been found, insert CD and press any key to continue. There is a black screen on my PC, no matter what CD I put in, or pressing any key, the message above just appear again on the...
this problem come from your har drive
your hard drive not recognized by motherboard
to solve, open your computer, disconnect hard drive cable then connect again
then turn on your computer
this problem usually found on computer with sata hard drive
Mar 31, 2011 | Computers & Internet
When i click on my computer to show the drives.my hard drives show but my cd and dvd does not show. windows says that the drivers loaded but cant find the devices. so i shut down to reboot then i pressed...
have you tried changing the lead that is used to connect the drives. Also if you are connecting more than one cd or dvd then try connecting just one to see if they are detected . If they are detected on there own then you have not set the jumpers on the back and they are conflicting over who is master or who is slave. there is three settings on the jumper master slave and cable select
Mar 12, 2011 | Abit Fatal1ty FP-IN9 SLI Motherboard
My Laptop no longer recognizes that it has a DVD/CD drive
If you can, remove unit from laptop and start laptop without CD/DVD. It is usually fairly simple to remove. Maybe a few screws in bottom of laptop. Cut off laptop and reinstall. Restart and windows should find it.
Jun 28, 2009 | Acer Aspire 9300-5349 Notebook
My computer crashed so I bought a recovery disk from tech guys, trying to do a full distructive recovery i get an error code 04 how can i fix i Advent 7113 laptop computer
Hi there.
Error code 04 means that the CD cannot be read properly, take the CD out and make sure its clean, also get a CD/DVD lens cleaner and clean the lens on the CD drive.
Please post back if you need any more help.
Good luck and thanks for using FixYa!!
May 11, 2009 | Computers & Internet
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
Dell Dimension 3000 PC Desktop Logo
59 people viewed this question
Alun Cox
