Question about Car Audio & Video
2003 Acura After body work on rear left, radio would not reset after disconnect using the correct number. Continue to get error message. Everything else in car works.
  • fman1 Aug 04, 2010
    So there is no homebound solution?
    I have a feeling I'll be taken for a ride.
    Top Expert:
  • Car Audio & ... Master
  • 82,322 Answers
U may have the wrong number or the wrong procedure after three tries the radio is locked out, contact your local Acura dealer on the reset procedure for this hard lockout.
Posted on Aug 04, 2010
  • Marvin
    Marvin Aug 04, 2010
    You asked for expert advice and u were given that, if u want to use the radio again you will need the dealer to help, there may be no charge for this is you ask nice. Good luck
    Genius:
  • 1,478 Answers
  • When the radio displays CODE, you may enter the code using the preset radio station buttons
  • For instance, my number is 1615, so when I get the CODE on the radio’s display, I press the radio preset button 1, then the radio preset button 6, then the radio preset button 1, then the radio preset button 5.
  • If your radio says OFF, leave the ignition on in the first position for 2 1/2 to 3 hours in order for it to display CODE. make sure you enter the correct code when entering the code.
Take care.
Need radio code for a 2003 acura 3.2cl types serial no be000970
That is not the correct serial #. If you cannot find it try to call the following number ACURA CLIENTS (800) 382-2238.
May 11, 2014 | 2001 Acura 3.2CL
I disconnected battery and antenna for 2003 acura tl but code wont take
on the TL - 5 digit code for the radio; 4 for navi; numbers are typically on a sticker on the side of the glovebox (nearest radio) or rear truck arm (great security acura?). Need to unplug the antenna and then put in the code, reconnect the antenna and your back in business. search the net to learn how to access the back of the radio. typically needed after power is lost to the vehicle, new battery installed, etc.
Oct 10, 2012 | 2003 Acura 3.2TL
I cannot find my owners manual of my 2004 Honda CRV and need to reset my radio. I have the reset code but need the instructions on how to reset it.
Method for all Honda/Acura vehicles except '03-'07 Accords with navigation system
1. The code is five digits, which will correspond to the radio station preset buttons that are numbered 1 through 6.
2. While the radio's display is showing COdE, punch each preset button once, IN THE ORDER GIVEN.
Example: Code is 62531. Hit the right-hand (6th) button first, then the 2nd from left, then the 5th from left, and so on.
3. If you have done the order correctly, the radio should start working after the last digit has been entered. If it does not, then you have made a mistake. You may try up to ten times (only three times on some models!), after which the radio will lock up and you need to then either disconnect the car's battery or wait one hour before trying again. If you disconnect the battery, disconnect both cables from the battery, then touch the cable ends together. Some radios have capacitors that will keep the memory alive for up to ten minutes. Touching the cable ends together will discharge the capacitors.
4. If you make a mistake in code entry part way through, CONTINUE entering ALL digits of the sequence of five, even if they are just random! You MUST finish the sequence of five in order for the radio to allow you to restart the sequence. or you can go to a honda dealer for instructions on how to reset radio. have a good day !!
Apr 09, 2011 | 2004 Honda CR-V
Code radio acura type
MAY FIND IT IN YOUR RADIO MANUAL, IT NEEDS TO BE RESET AFTER DISCONNECTING BATTERY
May 19, 2010 | 2003 Acura 3.2TL
I have a 2003 Acura TL and the power was disconnected and the radio code provided by the dealer does not work, what can I do? I've spoken with the dealer and provided the serial number and was told that...
You need to disconnect the antenna first. In the back seat where the top of the rear window meets the roof there is a little plastic cover. Slide the cover back and unplug the connector. Now enter the code then go back and reconnect the antenna. This will work if you have the correct code.
Sep 21, 2009 | 2003 Acura 3.2TL
Acura car stereo lock codes my stereo needs a code is a Acura 3.0CL now it says err-3 can some one help
err-3 means you have entered incorrect anti-theft radio code more that three times.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 30, 2009 | 1998 Acura CL
I need the code radio for acura integra ls 1997
Mar 26, 2009 | 2001 Acura Integra
Ford Expedition 2003 6 CD changer contianing 6CD's says CD error
Try unhooking the battery for 5 minutes to reset the stereo
Feb 25, 2009 | 2003 Ford Expedition
TSX reset radio code didn't work
Same problem with a 2002 3.2 TL; was jus advised that when OnStar switched from analog to digital it causes memory dump; dealer says it requires "hard reset" which costs ?$?; Acura 800 number says disconnecting antenna may/may remedy.
Feb 23, 2009 | 2004 Acura TL
Radio code
Replace the radio, something in the fuses probably not working.
Jun 21, 2008 | 2003 Acura 3.2TL
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
