Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Spdif pins Hello, I?m trying to hook up SPDIF to my Asus motherboard P4S533. Problem is, the SPDIF connection on my mother board uses a 3 pin connector. And the SPDIF connection on my Sound Blaster Audigy sound card uses a 4 pin connector but only seems to use 3 pins?. Can I hook these 2 up? But I need to know what these pins are. Which is SPDIF in? out? And which is carrying volts? I couldn?t find this info anywhere on your website. Please let me know.
    Sergeant:
  • 336 Answers
First of all when you got these pictures were they from *********** board?If they were did you wear a wrist bracelet to prevent Electro Static Discharge (ESD)? If not you may have just ruined your computer. But there is a chance you didn't. Next I am not positive but you might need to get a three pin SPDIF connector from Radio Shack. But I would try the one you have. See if it works. But I must warn you going inside your computer if you are not a technician can be very harmful to your computer. So if you take my advice Touch some part of metal on the outside edge so you are grounded to your computer.
P.S. Damage from ESD may not be right away. It can be months from when the computer was shocked. If my advice doesn't work tell me and i will give you much more help.
Hope this Helps.
RCF
Posted on May 27, 2008
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
Dec 29, 2012 | ASUS P5K64 WS Motherboard
945GCT - HM motherboard, SPDIF out?
Hi, Before doing anything please refer the motherboard manual, and as per my knowledge you need not solder any pin on the board, if you do so may be something else might not work. I better suggest you to check the Manual before doing anything.
Regards
Feb 22, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
MCP61PM-HM spdif pin assignment? trying to
+5v Out Ground
The one all by its self is the 5 volt
the one in the middle is SPDIF Out
the one next to this is ground
Nov 28, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Hdmi
Hi, =)
Basically what you need is to connect the S/PDIF out from the soundcard\motherboard I/O ports to the 8500 graphics card S/PDIF in and HDMI should now carry both video and audio.
So you have to check the video card. On the top part you'll see a white plastic with 2 pins inside of it. This is the connector SPDIF input from the video card. So what you have to do is look up in your motherboard for a connector with 3 pins that says SPDIF OUT. Even though it looks with 3 pins ONLY 2 of them are needed. You will basically need ONLY a cable like this:
http://www.tigerdirect.com/applications/Se...00&CatId=69
You can get it at a local pc technician shop for 2 bucks only.
Anyway what you do is connect one end of the cable to the two pins from the white connector from the video card and the other end of the cable to your motherboard on the first 2 pins of the SPIDF OUT connector. Now the way to know which ones are the first two, do it this way: The first two considering reading SPIDF OUT meaning that the first one is the one closest to the "S" letter of SPDIF OUT.
If it does not work trying connecting the cable differentely as you might be connecting in a reverse order (positive-negative). Don't worry about burning anything as it's only a sound cable, and it does not carry any power.
Once you do it, go to windows control panel and select SPDIF as your default sound playback.
And you're ready to enjoy sound and video thru HDMI now!
Aug 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Aug 11, 2009 | ASUS Intel 5000P Chipset...
ECS MCP61PM-HM SPDIF Header
diagram at HP support forum sows board and labels for connectors.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=87&query.id=879674
Oct 28, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
5,814 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
