Question about Danby DPAC8399 Air Conditioner
HAS COOL, DRY, HEAT, AND FAN MODE? WHAT DOES DRY MEAN?LIKE A DEHUMIDIFIER?
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Jan 30, 2011 | Sanyo Heating & Cooling
I av lost my manual. Pls kindly give me details on each of the samsung split AC 5way. I mean what each symbol means
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.Helpful?
Jan 19, 2011 | Heating & Cooling
I need help on how to activate heating mode in my 7wa4501q whirlpool 6th sense minisplit pleasee
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
4. Sun- Heat
Jan 13, 2011 | Heating & Cooling
What do the symbols on the display mean and which one does the cooling operate better on . model number kyd-32a thanks
Now symbols:
4. Sun- Heat
Dec 31, 2010 | Heating & Cooling
Don't have a manual i just wan't to know what settings are what ..re symbols on screen on control
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode.helpful?
I have a brand new york inverter air conditioner that does not want to cool!
Now symbols:
4. Sun- Heat
5. A or AU- Auto mode. First, check your compressor is working?
Dec 29, 2010 | Heating & Cooling
Why does the manual say not to put the air duct to the window when in the dry mode (dehumidifier)?
When you put the duct into the window you are sending the heat outside causing the unit to cool the house. When you run in the dry mode you need the heat to come back into the room keeping the room the same temp. This is how normal dehumidifiers work.
Oct 23, 2009 | Heating & Cooling
What is the function of dry mode in ac, when to use dry mode, and when to use cool mode and what about heat mode.
Dry Mode in AC is to dehumidify the room the fan cycles on and off and the indoor unit temperature drops below freezing which causes condensate to collect on the coil and as a result the humidity level of the indoor air is reduced
Jul 13, 2009 | LG L1204R Air Conditioner
Danby DPAC8399 Air Conditioner Logo
473 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
