Question about HP LaserJet 3030 All-In-One Printer
All-in hp 6130 will not print information at top of page
  • 3,153 Answers
This is usually down to the header of the page not being there or being blank.
You did not say what software you are using to print out the page so it is a little hard to guess.
If it is MS word or one of the MS products then you can access the headers and footers from the "VIEW" menu
From there you can select between header and footer to insert your desired text or date or page number etc.
If it is a different software package then just let us know and we will endeavour to help further
Bob
Posted on Aug 04, 2010
My HP Laserjet 2840 is showing "replace supplies" in the display. There are 5 box/cylendar's that appear in the display and the last one has a solid black box box in it. I was able to go thru...
Thank you for contacting FixYa with your printer inquiry.
The low ink could definitely be the problem thats prompting the error. To begin troubleshooting print the supply status page and confirm the state of the various supplies. Follow the steps below:
Supplies Status page The Supplies Status page lists the remaining life of the HP print cartridges and the HP imaging drums. It also lists the estimated pages remaining, number of pages printed, and other supplies information. You can print a Supplies Status page from the device or the HP Toolbox. To print from the device, complete the following steps. 1. On the control panel menu, press MENU. 2. Use the button to select Reports, and then press ENTER 3. Use the button to select Supplies Status, and then press ENTER. Note Supplies information is also available through the HP Toolbox.
This page illustrates conditions of consumables for Toner Cartridges, Image Drums, Image Transfer Kits, and Fuser Kits. It also provides ordering information and methods for disposing of or recycling used supplies.
Areas of Supply Status Page: 1. Print-cartridge area. This area contains a section for each of the print cartridges and provides information about HP print cartridges. This information includes the part number for each print cartridge, whether each print cartridge is low, and the life remaining for each print cartridge expressed as a percentage, as a graphic, and as the estimated number of pages remaining. This information might not be provided for non- HP supplies. In some cases, if a non-HP supply is installed, an alert message appears instead. 2. Imaging-drum area. This area contains the same information for the imaging drum that the print-cartridge area provides for the print cartridges. 3. Warranty Note. This section contains information about how the device warranty is affected when you use non-HP supplies. It also requests that you call the HP fraud hotline if a supply that is being detected as a non-HP supply was sold to you as a genuine HP supply. (See HP fraud hotline.) 4. Ordering Information. This section contains basic information about how to order new HP supplies. See Checking status and ordering supplies. 5. Recycling Information. This section contains a link to the website that you can visit for information about recycling. See Replacing and recycling supplies.
The product Support Manual is available from the below link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00341096/c00341096.pdf
If you have further questions just add comment to this link and we will gladly provide additional information and support.
Kind regards,
TF
Jun 08, 2011 | HP LaserJet 2840 Printer
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
How to count number of printings
Press 'Setup' - 2 - 4. This will print a Self-test report. In the top paragraph, Printer Information you will find 'Pages printed', followed by the total number of pages the machine has printed broken down by tray, total for all, and duplex printed.
Apr 23, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
Oct 23, 2009 | Xerox Phaser 6130 Laser Printer
My Hp PRINTER just started printing 1 page on to multiple pages ?
check paper size settings on both your pc and printer manu.
Sep 30, 2009 | HP Office Equipment & Supplies
HP officejet 6310 All-in-One When I try to print a copy of an airline reservation, from the ticket, or selected "print" on computer, it doesn't run off the ticket. It prints Page 1 of 1 on top of the page...
Make sure you're using the website's printer-friendly option when printing the ticket. Look for an option on the webpage (not in the pull-down file menu) that will correctly format the information for printing.
Aug 10, 2009 | HP Office Equipment & Supplies
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
PRINTS LAST PAGES FIRST...
All printers that I am aware of do that so when you pick up the page the first one is on top I have five printers
Jan 22, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Hp psc1410 printer
If you are trying to print from a web page keep in mind that not everything that is on the web is able to be printed. I would look for a link which is usually found near the top of bottom of a web page that usually says something about printing the page. An example would be if you use google maps to get directions. In the corner of the directions it says Print. If you click that link it would open the actual link you can print from.
Aug 20, 2007 | HP PSC 1410v All-in-One Printer
HP LaserJet 3030 All-In-One Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
