Question about Dryers
Burner control Fault at time of DSI module conversion Keys to controler are different from instructions Model ADG 75D Need to set purge to 10 Sec My KeyBoard has ABCDE 0-9 enter/Stop ClEAR/STOP
  • visionwd Aug 05, 2010
    Dryer is an Ipso gas ADG75D
    Serial No 37415GD
    Needing to set the purge to 10 Seconds unable to find out how by the keypad
    as instructions I have are for a different keypad with keys not represented by this one.
  • Dryers Master
  • 12,061 Answers
Www.fowlercompanies.com/.../ADC%20Service%20Manuals/AD-15%20thru%20AD-75%20Coin%20Phase4.1.pdf
Service manual and user manual all information is in those two manuals.
teetersproducts.com/images/.../ADC%20-%20AR850D%20-%20Service.pdf
http://www.acmehowto.com/howto/appliance/dryergoe.php
Above is a self help dryer servicing how to
Posted on Aug 05, 2010
  • 15,935 Answers
Please reply with the exact model # of dryer... and a clearer explanation of your problem.
Thanks!!
Posted on Aug 04, 2010
    Dryer is an Ipso gas ADG75D Serial No 37415GD Needing to set the purge to 10 Seconds unable to find out how by the keypad as instructions I have are for a different keypad with keys not represented by this one
P2176, 1682, 0443 on a 2005 envoy V8. Stalls and won't restart until it cools down
DTC P2176 Minimum Throttle Position Not Learned
Circuit Description
The commanded throttle position is compared to the actual throttle position based on accelerator pedal position and possibly other limiting factors. Both values should be within a calibrated range of each other. The engine control module (ECM) continuously monitors the commanded and actual throttle positions. This DTC sets if the values are greater than the calibrated range.
DTC P1682 Ignition 1 Switch Circuit 2
The ignition 1 voltage circuit supplied by the powertrain ignition 1 relay is used to power the electronic throttle control (ETC) circuitry internal to the engine control module (ECM). The second ignition 1 voltage circuit is supplied by the ignition switch through the ECM 1 fuse, and is used to power the remaining internal ECM circuits. If the ECM detects a voltage difference between the two ignition 1 voltage circuits, DTC P1682 will set.
DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit
An ignition voltage is supplied directly to the evaporative emission (EVAP) canister purge solenoid valve. The EVAP canister purge solenoid valve is pulse width modulated (PWM). The scan tool displays the amount of ON time as a percentage. The control module monitors the status of the driver. The control module controls the EVAP canister purge solenoid valve ON time by grounding the control circuit via an internal switch called a driver. If the control module detects an incorrect voltage for the commanded state of the driver, this DTC sets.
You have electrical problems of some kind , with out doing some testing with a scan tool an volt meter .Hard to say ! could even be the PCM shorting out after getting hot ! I have seen this happen a few times before !
May 05, 2015 | Cars & Trucks
What does code p0446 mean on a 2001 Buick Centry?
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction The code P0446 is set when the engine computer recognizes a fault or restriction at the vent control part of the Evaporative emission control system (EVAP). The description of the fault varies between different car manufacturers, but one thing is common, the code P0446 doesn't directly point to a defective part; some testing might be required to pinpoint the faulty component. What can cause the code P0446: - faulty vent control valve - blockage at the vent hose, vent filter or vent control valve - open or short in the vent control valve circuit - bad charcoal canister - EVAP system leak - faulty EVAP system pressure sensor - bad vacuum switching valve (VSV) - stuck open purge valve (solenoid)
Aug 13, 2014 | 2001 Buick Century
Purge fault enegin light is on
Hello
When the service engine soon light (Also called the check engine light or engine management light) is turned on this is to alert you to the fact that Powertrain Control Module (computer) has detected a failure somewhere in the systems it controls you may not feel any difference in the way the engine runs, this can be the transmission or the engine or emission system, there are fault codes set in the modules memory for these faults. What needs to happen now is to have the powertrain control module scanned with a special tool called an OBD2 electronic engine control scanner or a OBD2 code reader. Once the code(s) are read then you must perform the diagnostics for each code and make the appropriate repairs based on the findings of the diagnosis that was performed, this is called doing "Pinpoint" testing.
Sep 19, 2012 | Cars & Trucks
2004 BMW 325i I have a code p1447 do you know were to fix?
Fault codes do not have a single reason for being set, there are multiple reasons. here is the info you need to know about this code.
P1447 - Evaporative Emission Control System Purge Flow Monitor
Possible causes- EVAP canister purge volume control solenoid valve stuck closed
- EVAP control system pressure sensor and the circuit
- Loose, disconnected or improper connection of rubber tube
- Blocked rubber tube
- Cracked EVAP canister
- EVAP canister purge volume control solenoid valve circuit
- Closed throttle position switch
- Blocked purge port
Jun 13, 2012 | Cars & Trucks
The engine light wont turn off so I was told it was an evap leak but I dont know where to find it
Check the next diagram (click over image for zoom)...
Fig. Showing location of (1) Evaporative Emissions (EVAP) Canister Purge Solenoid and (2) Exhaust Gas Recirculation (EGR) Valve
Large Leak Test
This tests for large leaks and blockages in the EVAP system. The control module will command the EVAP vent solenoid ON, closed, and command the EVAP purge solenoid ON, open, with the engine running, allowing engine vacuum into the EVAP system. The control module monitors the fuel tank pressure (FTP) sensor voltage to verify that the system is able to reach a predetermined level of vacuum within a set amount of time. The control module then commands the EVAP purge solenoid OFF, closed, sealing the system and monitors the vacuum level for decay. If the control module does not detect that the predetermined vacuum level was achieved, or the vacuum decay rate is more than a calibrated level on 2 consecutive tests, a DTC P0440 will set.
Purge Solenoid Leak Test
If the EVAP purge solenoid does not seal properly, fuel vapors could enter the engine at an undesired time, causing driveability concerns. The control module tests for this by commanding the EVAP purge solenoid OFF, closed; and vent solenoid ON, closed; sealing the system, and monitoring the FTP for an increase in vacuum. If the control module detects that EVAP system vacuum increases above a calibrated value, DTC P1441 will set.
Small Leak Test
If the large leak test passes, the control module will test for small leaks by continuing to monitor the FTP sensor for a change in voltage over a period of time. If the decay rate is more than a calibrated value, the control module will rerun the test. If the test fails again, a DTC P0442 will set.
Hope this helps.
Apr 28, 2011 | 2004 Pontiac Grand Prix
I have a 2007 chevy trailblazer. The engine light constantly stays on and I had it to a mechanic and it showed the code P1440. Also, my traction lights, one with the wretch and the other light for...
Definition of check engine code P1440:
BMW:
Purge Control Valve Control Circuit Signal High
Citroen/Peugeot:
Purge Valve Stuck Open
Daewoo:
CANISTER V/V OPEN / SHORT
Ford:
Honda:
IMA System Problem
Hyundai:
EVAP System Vent Solenoid Circuit
Infinity:
EVAP Control System (Small Leak) (Positive Pressure)
Jaguar:
Kia:
Land Rover:
Evap System Purge Valve Stuck Open Fault
Nissan:
EVAP Small Leak
Volkswagen/Audi:
EGR Valve Power Stage Open
Volvo:
Subaru:
Fuel Tank Pressure Control System Low Input
Dec 16, 2017 | Chevrolet TrailBlazer Cars & Trucks
2004 niisan infinty g35x code p2135
NISSAN OBDII DTC
P1105 Manifold Absolute Pressure/Barometric Pressure Switch Solenoid Circuit
P1110 Intake Valve Timing Control Circuit (Bank 1)
P1120 Secondary Throttle Position Sensor Circuit
P1125 Tandem Throttle Position Sensor Circuit
P1132 Intake Valve Timing Control Position Sensor (Bank 1)
P1135 Intake Valve Timing Control Circuit (Bank 2)
P1137 Intake Valve Timing Control Position Sensor (Bank 2)
P1140 Intake Valve Timing Control Position Sensor (Bank 1)
P1145 Intake Valve Timing Control Position Sensor (Bank 2)
P1148 Closed Loop Fault Detected (Bank 1)
P1168 Closed Loop Fault Detected (Bank 2)
P1210 Traction Control System Signal Fault
P1220 Fuel Pump Control Module Fault
P1320 Ignition Control Signal Fault
P1335 Crankshaft Position Sensor Circuit
P1336 Crankshaft Position Sensor circuit
P1400 EGR/EVAP Control Solenoid Circuit
P1401 EGR Temperature Sensor Circuit
P1402 EGR System Fault Detected
P1440 EVAP Canister System Leak Detected
P1441 EVAP Vacuum Cut Valve Bypass Valve Circuit
P1443 EVAP Canister Control Vacuum Switch Circuit
P1444 EVAP Canister Purge Volume Control Valve Circuit
P1445 EVAP Purge Volume Control Valve
P1446 EVAP Canister Vent Valve Circuit
P1447 EVAP Canister Purge Flow/Volume Control Valve Circuit
P1448 EVAP Vent Control Valve Circuit
P1490 EVAP Vent Control Valve/Bypass Valve Circuit
P1491 EVAP Vacuum Cut Valve/Bypass Valve Circuit
P1492 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 Transmission Control Module A/T Diagnosis Communication Line Fault
P1705 Throttle Position Switch Circuit
P1706 Park Neutral Position Switch Circuit
P1760 Overrun Clutch Solenoid Valve Circuit
P1900 Cooling Fan Control Circuit
sorry but your code reader is not reading manufacturers codes ,if an american market vehicle then you should be able to read them but if this is a europeon model then how did you manage to get this code??
P0235....Turbo/Super Charger Boost Sensor 'A' Circuit
this is a generic code if its any help
Nov 02, 2010 | 2004 Infiniti G35 Sport Coupe
P 2138 code with service engine soon light on?
Accelerator Pedal Position Error.
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
Clear the code - if it recurs, change the sensor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 15, 2010 | 2006 Nissan Altima
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
201 people viewed this question
Top Dryers Experts
Marvin
Marvin
