Question about Hoshizaki KM-630M Crescent Cuber Ice Maker
Icemachine is going into harvest prematurely.Why is this happening?
  • Hoshizaki Master
  • 1,262 Answers
The grate under the evap plates have been known to break off small pieces. These pieces get caught in the discharge of the pump and hold open a spring loaded valve which then let water out and tricks the float into a harvest.
It's the white triangle piece with 3 screws in it usually just about or next to the pump. Look for broken pieces inside of it. Remember, when you take it apart, it's spring loaded.
Posted on Oct 12, 2010
Scotsman icemachine constantly freezing up no matter how small you put the setting?
Max harvest cycle just keeps it in a harvest longer. if you set the freeze setting to its lowest point and ice is still to thick then replace the freeze stat.
Feb 22, 2015 | Scotsman Ice Machine, Cuber, 1930 lb....
Ice getting to thick and not dumping
go to the freeze timer which has off and on dip switches. take some freeze time out by moving the first switch to off this will shorten freeze time. Also check the harvest assist solenoid and plunger when it go's into harvest. make sure the machine is cleaned and check the cube plate to make sure that none of the plates are not loose this will cause ice to freeze between the loose spots and will not let ice come off the plate.
Jul 21, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
How to get ice going
First is the machine making ice ? If it is making ice is it thick enough so the water comes in contact with the ice thickness probe. This has to happen so the machine will know it needs to go into a harvest. You should not have to fores it into a harvest it should be doing it on it on. There is a harvest button on the CM3 controller but when you push it its going into a harvest and when it finishes the harvest it will shut the machine OFF. I really need more info. What is it doing or not doing?
Mar 19, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I have a MV450 icemachine that work for up to 4 days without any problem .Then it cuts out the hi pressure indicator light up .i have checked the gas charge and cleaned the condensor
The magnetic switch just lets the machine know it finished a harvest and start ice production all over again. high pressure could be a dirty coil, fan motor stops working, a possible refrigerant restriction, or the room that the machine is in is getting to hot but this would cause the production of ice to take longer. it should be making ice every 15 to 18 mints in a 74 deg room.
Oct 05, 2013 | Scotsman Cooled Modular Contour Cuber Air...
Model #BD0603W. ICEMACHINE COMPLETLY SHUTS DOWN AFTER HARVEST
It could be a faulty Bin switch OR the water curtain not returning to freeze position.
B model tech manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 24, 2011 | Manitowoc Refrigerators
Scotsman icemachine cm506 stuck in harvest hot gas won't close any ideas?
check for power to valve coil. If it remains it's a control problem. If no power and still in harvest, valve is stuck. Unit usually does not exceed a 6 to 8 minute harvest.
Aug 17, 2010 | Scotsman Cooled Modular Contour Cuber...
Manitowoc ice machine that will not produce ice
This is odd that Manitowoc is listed on a page showing a Whirlpool refrigerator model and number. What is the model number listed on your Manitowoc? Not the base model number. The number listed inside the top section. Manitowoc has a really good service reputation. Their control boards have a series of self diagnostics. Get me your model and we will go from there. Sea Breeze
Jun 11, 2009 | Whirlpool ES5FHAXS Side by Side...
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
CME500 ICEMACHINE MAKES ON BOTTOM PART OF CUBER ONLY
Hi!!!Relax you just answer your question.If you went and advance the timer and it work but was stuck in the same position well its your bad timer.change timer and you will be fine..Good luck
Jan 05, 2009 | Scotsman Cooled Modular Contour Cuber Air...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-630M Crescent Cuber Ice Maker Logo
111 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
