Question about Kenmore Dryers
Dryer starts when button is pushed,but stops immediately when button is released. Model 62932
    President:
  • 1,554 Answers
The issue is with the motor relay. Hold the Push-to-Start button for a couple of minutes to check if the dryer heats up or not. If it does, unplug the dryer then pry the top of the console end cap trims and remove them. Remove the screws attaching the front corner of the console to the cabinet then rotate the console up.
Use the heater relay near the timer in place of the motor relay near the Push-to-Start switch. Make sure to take note of the wiring connections of the relays before disconnecting them. Rotate the console back into position then plug the dryer in and start it. Replace the motor relay (part number 3405281) if the dryer continues to run with the heater relay used. The relay looks like this:
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 04, 2010
  • 4 more comments
  • thomasjsween Aug 04, 2010
    I held the Push-to-startbutton for three minutes but the dryer did not heat up
  • Jahn27
    Jahn27 Aug 04, 2010
    Proceed with the interchanging of the motor and heater relays then let us know what happens.
  • thomasjsween Aug 05, 2010
    can you e-mail a wiring diagram to me @thomasjsweeney@windstream.net
  • Jahn27
    Jahn27 Aug 05, 2010
    Here's the tech sheet for your reference. It includes the wiring diagram you are requesting on page . The relays are parts labeled #15 and #36 in the exploded view diagram of the console.
  • thomasjsween Aug 06, 2010
    the moter and heater relays seem to be OK. I'm thinking the solution is to relace the even heat control assembly. What do you think?
  • Jahn27
    Jahn27 Aug 06, 2010
    Bypass the heater relay and if it heats up while holding down the start button, replace the main control board.
If i press the power button the dryer goes on but once i stop pushing the button it stops. I tried to keep the button pushed but the dryer doesnt heat up inside.
what kind of dryer is it and send the model number,if it's a whirlpool/ kenmore and it has even heat you have a bad even heat board...copy and paste and read this,it should help you out...............http://fixitnow.com/wp/2003/12/20/mailbag-dryer-stops-when-the-start-button-is-released/
Apr 25, 2011 | Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
PUSH TO START BUTTON DOES NOT WORK
its not the start button check the door switch if broken or actuator is broken you get the results as you dry
Aug 21, 2009 | Kenmore Dryers
Kenmore Electric Dryer M#62932
Check the door switch on the unit. The unit will not run if this switch is bad. Also, the thermal cut out needs to be tested as well. While you are at it, is the element bad? These are some things that can cause the unit not to run.
Apr 10, 2009 | Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
32 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
