Question about Fisher and Paykel GWL11 Top Load Washer
Even when I put the water level on high, the water does not cover the clothes in the machine. The batches of clothes are always medium or small.
    Top Expert:
  • Fisher and P... Master
  • 81,285 Answers
Check for a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Make sure the plastic tube is not obstructed or damaged in any way. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad switch
Posted on Aug 04, 2010
  • jechristina Aug 04, 2010
    Is the water level switch on the inside of the machine ? How do I know if the water level switsh is faulty ? Do I need to get a repairman to check this out for me or is this something simple enough for me to do ?
How much water does a LG wf/t8018 tp use ?
Hello..
Water level its all about how much cloth you washing. But dont fill the wash tub always maintain medium level
Feb 02, 2018 | LG Washing Machines
WHY IS WATER LEVEL LOW CAN I CHANGE THE SETTING ON WATER
there should be a knob on the control panel showing small, medium, large maybe even super. that is how you change the water level. Its for different amounts of clothing your washing at a time. If you put in a few clothes then you have the option of using less water.
Jul 31, 2014 | GE WBSR3140DW Top Load Washer
Does not sense clothes
most top loaders fill to the setting you enter into the program l( medium low high etc ) as the clothes absorb the water it will keep filling until a level is reached at which point that is the amount of water for the clothes and the machine will start you just have to think about how many clothes you are washing and how big they are ie blanket will be a big load and nickers will be small load
Jun 09, 2013 | Washing Machines
How much water should be in machine
It depends on the amount of clothes that is put into the TUB and it must be adjusted to the level required as low, medium etc.
The water level sensor will cut off the inlet valve when it reaches the desired set level. The water level should be a little over the clothes put into the tub.
Jul 02, 2012 | GE WSXH208A Front Load Washer
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
The water level never stops, it just fills till it over flows
if on auto level select water level eg medium or low depending on amount of clothes this sometimes works dont use auto water level. If not check small pipe under touch board on top panel, make sure u unplug mains from plug pipe may be loose its small plastic goes to level sensor on right of board. If not level sensor faulty.
Feb 21, 2011 | Haier HLP21E Top Load Washer
Bunn omatic won't make full pot-even with water line hooked up
Use the dial with numbers on it and adjust to a higher number. Remember to go in half steps such as 2 adjusted to 2 1/2, 3 adjust to 3 1/2 etc.
If you only have a High Low knob, that is to set your water temp.
If you have an electronic circuit board, you will need to follow the batch instructions pasted on the inside cover (facing the lower burner) to adjust for water level/batch. This cover has 4 screws.
Sep 08, 2009 | Bunn VPR Coffee Maker
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
16 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
