Question about Siemens 24 in. SL84A305UC Built-in Dishwasher
I have a Siemens dishwasher serie IQ which has had water damage. There has been water pressure on the drain tube. Probably the mashine has been partly filled with drain water. Now it can start and pump out the water, but it never starts any washing program. Well it starts and the time left (e.g. 15 min on the shortest program) is displayed. But then it does not start to wash or count down. Any idea what is wrong or broken? Anyway I can repair or reset the dishwasher?
hotuna
  • 288 Answers
SOURCE: kitchenaid dishwasher - water standing at end of cycle
How much water are we talking about? If its say less than 2-3 cups, It may be the way it is plumbed to drain. The drain line is back washing a little after everything is finished.
Posted on Dec 03, 2007
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
Krazytech
  • 725 Answers
SOURCE: Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Posted on Sep 19, 2009
  • 414 Answers
SOURCE: Siemens dishwasher pump runs while door open wont turn on!
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. There may be water in the base of the d/w (base as below the tank, not under the filter) this will activate the flood safety and give the scenario you have described, so check valve, hoses etc for leaks. You will have to manual clear the water from the base pan to deactivate the safety device. Sit the front of the d/w on a large tower and tip the whole unit forward, the base water will then come out. Whilst you have the side panel off, check that the red rod connected to the pressure chamber is not activating the microswitch. https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Posted on Jul 12, 2010
BElectric
  • 1140 Answers
SOURCE: Hello, i have a Siemens
It's possible that the Aqua-Stop flood protection system has been activated. I can probably help you, but I really need more information.
1. When you start a wash program, can you hear the pump running? - This will be a low pitch humming sound.
2. There is a dome/mushroom shaped plastic protrusion in the bottom of the washing compartment, located behind and between the salt compartment cap and the drain. Can you lift this up (be gentle) or is it already up and can only be pushed down?
Please post this information and I will try to assist you further.
Posted on Oct 27, 2010
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwasher won't drain water. Cleaned out the
it has to be a clog in the drain hose or drain pump has a restriction in it. if the you here a hum but not draining probably the pump is still good but its blocked. let me know with a4 thumbs up post
Feb 27, 2010 | Electrolux Frigidaire Professional Series...
Water won't drain from bottom of dishwasher. I pulled the dishwasher out, blew through the drain tube, disconnected the drain tube and felt around inside. Ok there. The dishwasher has not been in use for 4...
Sorry to hear that you are having problems with your DW.
Actually, yes. Not using a dishwasher for a while can damage some parts. Sediment from water damages the water valve. Food residues clogs the drain and drain pump. More likely the drain pump needs to be replaced.
Per your notes, looks like you are a handy main, so you may want to remove the pump to determine if it is clogged. (Quite dirty job). The drain pump is easy to locate, just follow the drain hose.
Also, check the connection with the food disposer under the sink.
Nov 15, 2009 | Dishwashers
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
Our Siemens dishwasher retains water and smells
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them.
If you find any food, it's probably that.
Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher.
You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
Sep 10, 2009 | Siemens 24 in. SE64A630GB Built-In...
Kenmore Elite Not Draining Water Completely
Check this link. Multiple causes are possible yet most is how drain is hooked up to disposal and back pressure built up. Hose must be installed correctly.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Siemens Dishwasher - no water coming in
It could be 1 of 2 things, first (most likely) is that by turning it upside down some dirt has gotten into the pressure switch, that's a disc shaped device with 1 or 2 small tubes and some wires attached. in this case you have to find the switch (usually high up on the front or back) remove the longer tube and blow down it to clear the blockage.
Or it could be your inlet valve is not working, this needs ac mains on it, for a solenoid that opens the valve, again you may need to remove it & see if the coil isn't burned out, either a multimeter or just put mains on the 2 wires & hear if it clcks open. Inlet valves can sometimes get blocked, so they don't get the pressure needed to open, i also had this problem in a high-rise flat where the water pressure was too low!...hope this helps...
Mar 24, 2017 | Siemens Dishwashers
Siemens 24 in. SL84A305UC Built-in Dishwasher Logo
144 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
