Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I have a Mitsubishi Mr Slim PK36FK3 and i get error 8 on the codes. I have cleaned the filters and checked to see there is nothing blocking the condenser fans. The fuses do not blow and the breaker does not trip. The unit stops and the green power light flashes with error P8. I can turn it off and on again and it will run for a while. Then the same error messages comes up. What is the problem????
    Brigadier General:
  • 3,513 Answers
Hi
There are many things that can trigger that code. The most likely is a power problem...ie. Outage. Reset, and Recycle the power off and on and it take off and run.
Other things to check are:
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
5 loss of charge
The most likely of these is number 5 .. In cold weather you can be just a tad low and when it gets REALLY cold then the loss of charge switch shuts you down. If you are below -10 F then it can do that even if you are fully charged.
Please check the bellow links and visit the forum to get an idea regarding your query…
http://hvac-talk.com/vbb/showthread.php?t=53149
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I´m P-08 code
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Due to short of gas/evaporator & air filter blocked/less rpm of blower motor.
Remedy: Find leak and arrest and do gas charging/clean filter & coil/replace B.Motor capacitor.
Jan 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
It is a ducted Airconditioner When started after few minutes it stops and a control panel indicates: check P08 with kind regards annurag anurag@maluxme.com
Code P8
Check may be icing in your indoor coil due to evaporator coil /air filter blocked- Clean it.
Short of gas or gas leak. Call repairman to find out the leak & arrest to recharge gas.
Helpful?
Dec 25, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr.Slim keeps freezing up
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
Jul 18, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Jun 06, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Right Indicator light blinks; left is solid; nothing in manual about this pattern
that is an error code.
count how many blinks after a pause and that would be the error code.
could be 4 , 5, 7, or 9.
you could reset it by un plugging or removing power for ten minutes and try it again.
if the problem would re-occur, then there is something wrong with the unit.
as it runs, observe everything and keep me posted. see if the fn outside is running, if the filter is clean, or if the compressor is running, etc.
tnx 4 using fixya,
drcool
Oct 04, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
184 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
