Question about Whirlpool CEM2750TQ Electric Dryer
Dryer runs but does not heat up. undid hose to make sure it was clean no lindt, and fliped braker. still no heat.
  • Whirlpool Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
Dryer is not heating up
First Check for the correct voltage 220volts The dryer will run with only 110 reset the Braker.
You will not get heat with only 110 volts NOW Unplug the dryer . NOw you must take the dryer apart from the front most dryer. look you the heating elements some are in the back arown the back of the drum others are on the left on the bottom Not sure of your dryer model. Look for brakes
In the coils if the seem ok. Then check the Hi-limit Thermostat with volt meter or ohm meter.
I think its best to check all the Thermostats and the Thermal fuse. then you don't have to go back
Over then again HOPE THIS HELPS ALWAYS UNPLUG THE DRYER, SAFETY FIRST
Nov 21, 2010 | Dryers
Stops drying after short time
I'm no expert. In fact I was having the same issue that your are with the dryer cutting off after running a short time and after googling and coming across your post I thought maybe I had a similar issue. Not so much that I needed a hard line but that the vent duct was clogged and so the dryer built up too much heat. I undid the vent hose and looked into the vent pipe and sure enough it was full of old lint. I was able to go under my house and undo the vent pipe and **** it out with a Webster cobweb brush. Not real easy but not to difficult either. The dryer seems to me much happier now.
May 08, 2010 | Fisher and Paykel DE06 Electric Dryer
The dry will not get hot the knob had sparks that came from it
there are many different things that could lead to no heat condition,first check the input power terminal strip where the power cord enters and make sure the leads arnt burnt off,then the hi-limit switch found on the heating element case can be bad,an open heating element, a bias thermostat in some machines,you will need to open up the machine to check most of these parts except the power input with a multi-meter
Jan 12, 2010 | Speed Queen AES28AWF Electric Dryer
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Dryer getting hot but not drying
YOUR DRYER will start and run with only 110v. applied to it...........................How ever you won't get heat without 220v..........after you run dryer a few minutes you should feel HEAT inside.......my guess is you have no heat but the dryer runs,,,,,,,? If this is so, you probally are not getting 220 volts. you either have a blown FUSE or a bad circiut BRAKER in your main panel... remove cover (the small one) on back of dryer where the plug cord goes in....get someone with a voltmeter to check for 220v. going in to your dryer,,,,,,,,,,BLACK(wire) toWHITE(wire)=110v...........RED(wire) toWHITE(wire)=110v.........BLACK(wire) to RED(wire)=220v.............Let me know how you make out....P.S. don't go on ROOF..!!!!
May 11, 2009 | Whirlpool LER5636P Electric Dryer
AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
May 11, 2009 | Amana DLE330RAW Electric Dryer
Whirlpool dryer model wed5300sq0
My dryer heats but it takes more then 3 x to get the clothes completely dried. Why does it take triple the time to dry my clothes now.
Jun 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Whirlpool CEM2750TQ Electric Dryer Logo
46 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
