Question about Kyocera Copystar CS-1820 Black and White Copier
The screen say "remove original document from processor" and there is definitely not a document stuck in the machine!
    Problem Solver:
  • 8 Answers
There is a 3 inch long plastic arm under the top door of the top feeder. This is a sensor arm. It is most likely broken. See your local copystar dealer for a replacement part.
Posted on Aug 05, 2010
Printer reads remove original from document processor but there is no jam.
dear
any of the document sensor defective or its lever latched.
The sensor may be replaced or re aligned levers may overcome the problem.
Thanks.
Feb 11, 2015 | Office Equipment & Supplies
How to reset kyocera km 6030 Double sided copy mode. When i want to copy double sided page then i will see in screen... ""Reset All Originals in Document Processor ""
I think the message is "Reseat All Originals in Document Processor". This message apears when there was a misfeed or something like that. It means that you must put back all the documents, to be scanned again. Clean the paper feed/pickup rollers with a cloth dampned in alcohol.
Jan 21, 2015 | Kyocera Office Equipment & Supplies
Stuck on toshiba logo screen.
Dear Branden,
Please remove the battery and wait for 30 sec, after that insert the battery back and turn on the machine
Regards,
Samy
Aug 10, 2014 | Toshiba SatelliteR C855D-S5900 Laptop...
"remove original from document processor"
Sensor in feeder is probably broken. To get around this until you can get it fixed power down the unit and unplug it. Unplug the cable that connects the Doc feeder (in the back) to the main unit (two screws hold it on. Then power the unit back up it will work with out the Doc feeder. You will just have to put the copies on the main glass.
Jun 29, 2011 | Kyocera Copystar CS-1820 Black and White...
This machine was running a 1.2 processor which I now know is the fastest processor the mobo will support. However, and before I knew this, I placed a 1.53 processor (AX1800DMT3C) in the slot and the bios...
The original CPU was 1200 Mhz, namely 12 times the 100 Mhz "clocking" supplied by the motherboard.
The new CPU is 1.53 Mhz, namely 11.5 times a 133 Mhz clocking, if the motherboard can supply that rate of clocking.
If your motherboard can only supply 100 Mhz clocking,
then the new CPU would run at 1150 Mhz (namely its 11.5 multiplier over the 100 Mhz clocking), i.e., slower than the original CPU.
Can you try the 1.2 processor in some other motherboard?
It's possible that you "killed" it, when you removed it,
or after you removed it, by giving it a static-electricity burst.
Do you have another processor that you can try in your motherboard?
What happens if you put the 1.53 processor into the motherboard?
Does it POST (Power On Self Test) ?
Sep 01, 2010 | Sony VAIO PCV-RX460 PC Desktop
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Original jammed in fax feeder of Brother Intellifax 2800
    lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
    May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
    Can you help with kyocera cs-1820
    Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
    Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
    Deleted document
    No you can't the original file has now been replaced.
    It's no different from deleting the file in the first place than creating a new document with the same name.
    Aug 17, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Original document stuck in feeder of HP OfficeJet 6110 All-In-One
    ok...this is not that hard...you'll need to open up the top of the machine, and most likely remove some components. Take a look at this link first though Got backup?
    Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
    Kyocera Copystar CS-1820 Black and White Copier Logo
    236 people viewed this question
    Top Kyocera Office Equipment & Supplies Experts
    Chris Schutte
    Marvin
    Marvin
    Adorjani Laszlo
    Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
