Question about Sharp EL-1701C Calculator
When I am adding several numbers all of a sudden I get a 'P.E in the screen and the machine won't do anything else until I clear and start again. What does this mean?!?!?!?
    President:
  • 2,030 Answers
Its an internal problem with the main board. cant really fix it just have to replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 06, 2010
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Won't start
sounds like you have a bad motor,when it heats up it stops running and when it cools down it will run again but one of these times it won't run anymore until you change out the motor.when the motor gets hot you might smell a shellac smell,this is the windings on the motor heating up.part number 8528157 and it's around 120 dollars on the sears site
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00005?blt=06&prst=&shdMod=watch this video to change motor
http://www.youtube.com/user/RepairClinic?v=Oeiyjt7807o&feature=pyv&ad=5457341981&kw=washing%20machine%20motor
May 07, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine stopped mid cycle, won't spin or did not drain, no error code displayed, tried unplugged and restart. no luck
next time send the model number,open the door,look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,it has to drain first before it will spin,check the pump,get a shop vac and vac out all the water,remove the bottom panel and look at the pump,if the middle of the pump can be removed turn it counter clockwise slowly until the water starts to leak out and vac it up until all the water is out,then remove the middle part of the pump and clean it out,if the middle doesn't come out remove the hoses and check the pump to see if anything is in it and check the hoses,after you remove any debries you find fill it with some water and put it into a drain to see if the water drains,if it doesn't you can check the pump again to make sure you cleaned everything out,stick your finger in and fell around the impellar to make sure it's clear,if it's clear replace the pump.usually an error code will come up but if it fills and agitiates but won't drain i would start at the pump.hope this helps.
Aug 15, 2011 | Maytag EPICz 3.7 Cu. Ft.
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Jun 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
I ahve the same problem as lucyjh
Try to increase the screen resolution to 1920 x 1200.
Jul 23, 2009 | Dell Studio 1737 Laptop
Hi i have photo copier minolta dialta di183
Enter the admin mode (U-5) by holding down the Panel Reset key for 3 seconds (until "U- " appears in the display), entering the number 5 from the keypad, and pressing the start key. Enter the 6 digit administrator code and press the start key again. The display should show "Ad-". Enter 1 from the keypad and again press the start key. The display should read "0". Hit the clear key, enter "1" and hit the start key yet again. Hit Panel Reset several times (or turn the machine off and back on) to return to normal operation.
The default administrator code is 000000.
If you do not know the administrator code, it will be necessary to reset it using the tech rep mode. Enter the tech rep mode by pressing the Meter Count key and hitting "Stop - 0 - 0 - Stop - 0 - 1" quickly. Then hit 7 and the start key. The administrator code will flash. You can write it down and use it, or hit the clear key and enter a new code, then the start key. Exit as above.
Jul 03, 2008 | Minolta DiALTA Di183 Copier
Memory full ux300
to clear memory(which i must warn will clear everthing) first press function then press the number 9,next press * (asterict) then press the number 8 then press the # key then 7 key, press start, you should see a ram version on screen,then press start again,next press # key untill it say's memory clear,press start and it should say memory clear.
Sep 23, 2007 | Sharp UX 108 Roll paper Thermal Fax
Sharp EL-1701C Calculator Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
