Question about Microwave Ovens
I have a stainless steel sink in my RV. When it was stored for the winter, I used FRI-Z-AIR containers to absorb moisture. Some of the crystals spilled into the sink and actually etched spots into the sink which look like rust. I have tried stainless steel cleaner on them to no avail Suggestions?
  • 576 Answers
I would try SOS pads or even fine sandpaper if necessary. Make sure you go with the "grain" so it isn't obvious afterward. It is possible to blend with those grain lines in stainless steel, we used to do it in a factory.
Posted on Aug 04, 2010
Tip
Using stainless steel utensils in a microwave oven
Every one knows that one cannot use metal utensils/bowls in a microwave oven.
But did you know that this does not apply to a utensil/bowl made out of stainless steel?
Try it this way.
Put some water in a stainless steel container and place it in the microwave for 5 seconds.The water will heat up without any sparks being created.
One could actually heat up anything in this way without any danger of causing a fire.
on Apr 10, 2014 | Microwave Ovens
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Nov 30, 2013 | Dacor MWO30S Millennia Series Warming...
Is the dry mode on the airconditioner a dehumidifier
Air conditioners and dehumidifiers both work on the same idea. A dehumidifier is a "air conditioner" that doesn't run so good as a air conditioner, plus, it sits on the floor in your basement (where ever) and not in the window.
The idea is to draw warmer air (which holds more moisture) into the machine where it is chilled (cooler air can not hold as much moisture). The moisture is deposited on the coils and it drips either to a drip pan (where it runs out the back to the outside (AC)) or a catch bucket (in a dehumidifier and you either dump it in the drain or you have connected a hose and led it to the drain). The air that is returned to the room contains less moisture than it did when it entered the device. The best relative humidity is about 50%, BTW. Not to wet and not to dry.
The goal in the case of a AC is cool air (which contains less moisture) and the goal in a dehumidifier is less humidity (moisture), but not necessarily cooler air.
I am not familiar with "dry mode" to which you refer. You have mentioned your device is a Goldstar Microwave Oven so it is impossible for me to gather any information on your particular model AC or dehumidifier.
I hope this information has helped you today. Thank you for your interst in FixYa.com. Please make a favorable evaluation of this response.
Jul 18, 2011 | Goldstar Microwave Ovens
I seasoned my new stainless steel skillet in the oven now I have built up oil stuck to the sides inside the skillet. How can I remove this without damaging the stainless steel finish? HELP!
You only need to season a cast iron skillet, not stainless steel. Soak it in hot soapy water and use something like a mister clean pad to clean it.
Dec 07, 2010 | Microwave Ovens
How to clean GE Advantium???
Get a stainless steel "brillo pad" at the grocery store.
When you get home ... put a microwave safe container with water inside it ... in the oven. do not heat for more than 2 minutes!!!!! The resultant steam will soften the gunk. Use the stainless steel cleaner pad gently to remove the goop.
I hope this helps you
a
Sep 23, 2009 | GE Advantium 120 Convection/Microwave Oven
No homegrown popcorn in a microwave? why?
Popcorn is a food that has a very low moisture content, and microwave ovens rely on moisture content (water molecules) in order to cook.
If there is not enough moisture to absorb the microwave energy, much of the the energy is reflected back to the magnetron and damage it.
This is also what damages a microwave when it is run empty.
A simple solution is to add about 1/2 to 1 cup of water in a microwave-safe container in the back corner of the oven and cook your popcorn a little longer.
You'll have to experiment a few times to get the combination right for your particular model.
But allow our microwave about 15 minutes or so for the magnetron to cool down between popcorn cooking sessions.
Also, I would suggest putting a paper plate upside-down on the turntable tray, then putting the popcorn container on top of that.
This does two things: It keeps the extremely hot popcorn off the tray, reducing the chances it will crack, plus it raises the popcorn up so it will heat more efficiently.
Dec 23, 2008 | Microwave Ovens
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Feb 05, 2008 | Amana ACM2160A Microwave Oven
Microwave Ovens Logo
56 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
