Question about Tricity Bendix TM310W Electric Dryer
My tricity bendix dryer TM 320W is heating up but it's takeing at least 3 full cycles to dry the clothes and the water tank is hardly ever full, whereas i had to empty it after ever few loads before. any ideas?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Check the condensor is clean.the most overlooked reason for this is failure of either the seals at the front and rear of the drum allowing the closed cicuit heated air and there condensing air mixing. check the seals its usually the rear one.
Posted on Aug 04, 2010
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
Apr 05, 2016 | Tricity Bendix Dryers
Goes through full cycle but does not heat to dry clothes
Check the thermal cut out which is situated next to the cycling thermostat , above the heater , they come as a pair .
Mar 06, 2015 | Tricity Bendix TM310W Electric Dryer
Dryer not drying
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Feb 18, 2014 | Tricity Bendix Dryers
My tricity bendix tm320 heater wont heat on half heat but will heat on full heat
Jan 14, 2014 | Tricity Bendix TM310W Electric Dryer
Tank empty but water on floor under ,machine but clothes seem dry
HAVE YOU CLEANED THE BIG STEEL FILTER IN THE BOTTOM OF THE DRYER UNDER YOUR TAP ....... THATS WHAT IT MOST POSS IS TO REMOVE BLOCKED FLUFF
Dec 24, 2010 | Tricity Bendix Dryers
Tumble dryer running but not heating up its a tricity bendix tm 545
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Dryer shorts out some of the electrics when its switched on!
The breaker in your breaker box is either weak and need to be replaced or the amps is too low. But from what you stated, you have had this dryer for awhile, so I'm assuming that its just a bad breaker. If the dryer still runs and doesn't have any issues when it dosn't pop the breaker, then this is what it is. Have an electrician come out and replace the breaker if you are not familiar with doing this.
Apr 10, 2009 | Tricity Bendix TM310W Electric Dryer
Dryer
We found that we needed to turn down the water inlet to almost off and then the dryer worked when we had the same problem.
Remember to turn it back up again before the next wash
Mar 13, 2008 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix TM310W Electric Dryer Logo
529 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
Marvin
Marvin
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
