Question about GPS
Error message,failed to open file:igo/480_272/loading.bmp exiting application. clarion map 670 sat nav,seems to be in constant loop trying to pair phone on bluetooth and above error appears when selecting navigation?
The solution that worked for me is: in your iGO installation folder, open SYS.TXT file then find section [interface] next check if exist something like this: skin="ui_igo8" if not then add it, but you must first check in your DATA.ZIP file what is the name of the folder it can be ui_igo8_da, ui_igo8_pda... depending on version. After that iGO will load normally. One more thing, I've added this section at the end of SYS.TXT file [loading] show_statustext=1 show_progressbar=0 progressbar_x=62 progressbar_y=174 progressbar_bmp="loading_progressbar.bmp" ;you can disable this line bu putting ; sign at the beggining loading_bmp="loading.bmp" ;you can disable this line bu putting ; sign at the beggining
Hoppe this will help you!
Posted on Feb 22, 2011
Have paired the sat nav with phone and they are seeing one another, but when I click the answer call on sat nav no sound is coming from sat nav have turned volume fully up can u help regardss
Search Results
    Troubleshooting voice navigation issues, including vehicle ...
    productforums.google.com/d/topic/maps/NR6xxNE5vQw
    Google
    Aug 21, 2014 - 100+ posts - ‎100+ authors
    Basically to work like a satnav does. .... Have been using Google maps and voice navigation with no prles since May. ..... The audio does come out from the phonespeaker even when my Bluetooth is paired to the phone.
Oct 24, 2015 | GPS
I got a clarion nx 602, I install it everthing works eccept the navigation system. Say failed to start at first time.
I have the same issue. Started a few weeks ago by locking up the unit while using the nav. Then the nav app will not load at all. Any luck on getting a resolution?
Dec 16, 2012 | Clarion NX602 6.2in DOUBLE-DIN NAVIGATIO
I just installed rocky mountain trophy hunter versions 2 and 3 on my computer and am having problems with both. My computer is saying that RMTH 2 is not a valid win32 application and i cant install RMTH 3...
For RMTH2, make sure you have the 1.1 patch and try again. If it is still failing, copy Rmth2.exe directly from the install CD into the folder that has the same filename and overwrite the installed one.
For your RMTH3 issue, it is usually caused by older software not being able to find the temp directory. Try copying the setup files to somewhere like c:\temp and install from there or set your temp variable to c:\windows\temp instead of your profile temp folder.
Apr 19, 2017 | Rocky Mountain Trophy Hunter 3 for Windows
My sat nav shows opposite direction map
Binatones run igo. I would recommend finding the latest software and trying an update - then see if the problem still occurs. There is also a setting in the map view for making the map change to the direction of travel - this may be causing an issue.
"austech" is a good place to start.
Feb 19, 2010 | Toymax Binatone Carrera X350 Car GPS...
Faulty Sat Nav
Have you tried resetting the unit? if not try this as it solves many problems
Dec 31, 2009 | GPS
What is the OS of Garmin Nuvi 205 Sat Nav, will it accept map like Igo 8 or other maps
No, Garmin units are set to proprietary mapping so you have to use Garmin or Garmin-compatible maps.
Nov 29, 2009 | Garmin nuvi 205 GPS Receiver
Fatal application error on evesham 6200 sat nav
check that you have any maps loaded. They may well have become coirrupted or erased
Jul 25, 2009 | GPS
Satnav Problem
I purchased this sat nav only a couple of weeks ago :@
and when i punch in a post code for it to take me to the place i want to go it shows me the wrong way and it switches off on it own this is really irreating and im pissed off so anyone know what to do then i would be greatful from -- Jordon Carrter :)
May 18, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Alpine sat nav would not load...
This is not uncommon, before resorting to Alpine, try a DVD cleaning disk. It may be necessary to try it up to 6 or 7 times, but it's a lot cheaper than dealer service!!
Mar 09, 2008 | GPS
Nav-u.exe Exception
By MS Active sync from computer delete file Mounted Volume/my flash/sony/nav-u.exe (the folder SONY is hidden, you must set show hidden files in your comuter first). And then replace old navi file by exe file of total commander CE version ( download is free on site of developer) .You must rename the totalcmd.exe to nav-u.exe. Now after reboot is allowed everything, including executing any other navi software like tomtom, igo, navigon and many other (multimedia players). The oficial navi (old navigon) by sony is not so good in compare with new navi soft. .. enjoy.
Feb 08, 2008 | Sony nav-u NV-U70 GPS Receiver
GPS Logo
6,649 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
