Question about Goldstar MV-1526 Microwave Oven
Goldstar MV-1610 Microwave
Everything works, just will not heat up.
  • ABEJITA May 13, 2008
    HI, I HAVE THE SAME PROBLEM, EVERYTHING WORKS BUT IT WONT HEAT, I TRIED THE CHILD LOCK AND NOTHING, WHAT ELSE CAN I DO. THANK YOU
  • Goldstar Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have a service manual for the MV-1615, which is similar. I have uploaded it to our site here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
I have a Goldstar mvh1615ww series microwave that will not heat.Everything works but it will not heat.Please help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 24, 2010 | Goldstar MV-1615 Microwave Oven
Microwave does not heat goldstar mv 1500 mg
heatman101
Aug 05, 2010 | Goldstar MV-1526 Microwave Oven
MICROWAVE NOT HEATING AND TURNTABLE NOT WORKING BUT EVERYTHING ELSE DOES. WHAT IS THE CAUSE OF THIS?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
89r
Nov 30, 2009 | Goldstar MV-1155 Microwave Oven
Goldstar MV1515W running but not heating
One of two things will be the problem. 1)almost certainly the magnatron. 2)the cap and HV diode need to be checked and possibly replaced.
Sep 17, 2009 | Goldstar MV-1515 Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Turn off Demo Mode on goldstar Microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
Otherwise, try holding CLEAR for 3 seconds, then try each pad for 3 seconds.
Sep 07, 2008 | Goldstar MV-1615 Microwave Oven
MV-1610 Runs but doesn't heat
That wouldn't be a resistor on the capacitor, it would be the high voltage rectifier diode.
It should read open on a continuity check. A shorted high voltage diode is a fairly common cause of a no-heat condition.
For testing, see: http://www.gallawa.com/microtech/diode.html
To order the part, and for other Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
Jun 22, 2008 | Goldstar MV-1615 Microwave Oven
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar microwave mv-1526 1000 watts
the bullet fuse to the klystron circuit may have blown
it is a thermal bullet fuse ,
google that to see what it looks like.
if you have a ohm meter it will give low ,closed resistance.
Apr 25, 2008 | Goldstar MV-1526 Microwave Oven
Goldstar MV-1526 Microwave Oven Logo
185 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
