Question about Bosch Nexxt WTMC3321US Electric Dryer
As describe earlier, my dryer started smoking, and maing a burning smell from behind the drum. There is no evidence of lint buildup in the exhaust, and the dryer still starts smelling as if it is on fire when it is disconnected from the exhaust pipe.This smoking/fire smell has never occurred before. I had just dried a medium load, and was just restarting it with a few items to toss before I put them on the clothes line,when it started smoking. I found this site, and thought I would try and contact you, before calling for service.
I just had this problem. Did you notice the lint buildup under the lint drawer? Well, there is no way to recover that lint, it is not accessible by the consumer. So the lint bits get sucked in to the out take which actually pulls across the hot element. The "solution" is to replace the element and the parts surrounding. It is very expensive, and does not resolve the issue. The lint will continue to be drawn across to that area and build up and become a fire hazard. I am about to try Bosch for a solution, but that is what they have told me for now. Eventually this make/model of dryer will burn someone's house down. I am very glad I was home when the smoke detector went off. I will have to get a new dryer.
Posted on Dec 03, 2010
A burning smell inside the drum when I use the gas dryer
The burning smell is usually one of two things. If it smells like burning rubber the dryer belt is on its last leg and is slipping or stuck. If you are a diy'er the replacement of the belt is more time consuming than difficult. If it just a burning smell, then it is most likely lint built up inside the exhaust. You'll need to scoot the dryer out and get behind it to take off the dryer hose that vents from the dryer to the outside. Take off both ends for the most convenient and thorough cleaning. You'll need to blow out the hose with an air compressor and/or push a cylindrical brush through the hose or a rag on the end of a long stick. Be care not to puncture the hose! Once done, you are not finished cleaning. The back panel of the dryer needs to be removed to access the exhaust's internal pathway. You can try to clean it from the lint trap and the place in the rear where the dryer hose attaches, but be aware that cleaning cannot remove all the lint stuck to the exhaust pathway lining. At Home Depot, Lowe's or Menard's they sell brushes on wire, etc to clean the dryer's inside exhaust pathway.
Hope this helps!!
Jun 13, 2016 | Dryers
I have an asko dryer T712C which after 5 years has a burning smell and the sheets that have been in smell of smoke
be careful as this sounds like a big fire hazard. Could be aa faulty thermal cut-off or lint buildup trying to catch on fire.
Aug 05, 2012 | Dryers
I smell a burning smell. when i open the dryer, there is smoke
Firt make sure the lint filter is clear and the air exhaust pipe is clear. Then check the drum gasket. Behind the drum, there is a heater.The drum rotates and the heated air is passed from the stationary heater to the drum via a gasket, usually stuck to the back of the drum andthis rubs against the stationary heater wall. This gasket can become frayed or broken and bits can be ignited by the heater. The gasket will need to be replaced if this is the problem.
May 19, 2011 | Whirlpool LEW0050P Electric Dryer
Smoking like the dryer lint is burning
Sounds like you have a lint problem within the vent hose and or the dryer...
Clear you lint from both and follow the parts needed in the solution below.
Or could be a belt also burning...
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Apr 14, 2011 | Kenmore 700 6972 Dryer
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
My clothes come out of the washer smelling fresh and clean. After drying in the dryer, they smell mildewy.
Check for lint buildup in the vent discharge hose/pipe and the inside of the dryer blower housing.
Heavy wet lint buildup will cause a moldy/mildewy smell that you describe.
Heavy lint build up will also increase the drying time, and it is a fire hazzard
This is a free answer, Please rate me
Oct 18, 2010 | Estate Dryers
SMELLS LIKE ITW BURNING
I highly recommend opening the dryer by removing the front panel.
Unplug the machine, remove the front cover and be prepared to vacuum out the lint build-up inside the housing of the dryer.
Also clean the exhaust duct of lint buildup too.
Sep 12, 2009 | Whirlpool Dryers
Duet Gas Dryer- burning smell
first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dec 29, 2008 | Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer won't start. #63841
IF THERE IS A RESTRICTION IN THE EXHAUST(LINT BUILDUP OR FOLDED FLEX ATTACHED TO THE DRYER AND PUSHED UP AGAINST THE WALL) THE DRYER WILL NOT DRY PROPERLY. IF THE PROBLEM IS NOT FIXED, A THERMAL FUSE WILL OPEN SHUTTING DOWN THE CIRCUIT TO THE MAIN MOTOR. THE THERMAL FUSE IS A SMALL WHITE OBJECT LOCATED BEHIND THE BACK PANEL DOWN BY THE EXHAUST OUTLET. THERE ARE TWO WIRES ATTACHED TO IT. IF IT IS BAD, REPLACE IT AND CHECK THE DUCT WORK FOR ANY RESTRICTIONS.
PART COST APPROX 30 DOLLARS
Mar 31, 2008 | Dryers
Bosch Nexxt WTMC3321US Electric Dryer Logo
1,252 people viewed this question
Top Bosch Dryers Experts
Marvin
Marvin
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
