Question about Lands Phones
I am using avaya IP agent voice over system there is a problem with the sound coming through the headset. There is nothing wrong with the headset but all of the volume is coming through the pc tower. It will not let me change the headset brand under the 1 type and it is not mine.Under volume & ringer settings the slide bar under record is all the way to the bottom and will not let me slide this up.
SparkGap
  • 363 Answers
SOURCE: Echo problems
Check that the MIC is muted in the volume control but not in the recording settings. This could just be feedback.
Posted on Oct 01, 2007
  • 38 Answers
SOURCE: no sound coming from speakers.
Did you run the audio cable from the computer to the monitor. If not you must have that for the speakers to work. If yes can you verify computer output with another pair of speakers to narrow it down to computer or monitor. If it is the monitor built in speakers that are the problem reply and we can go through a procedure to get them working.
Posted on Jan 18, 2008
TampaNative
  • 778 Answers
SOURCE: Sound Monitor Compaq FP 7317
You need the proper driver for your monitor, and you will find it here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&product=324199&dlc=en&lang=en
If you require instruction on how to update the driver, let us know?
Good luck.
Posted on Mar 21, 2008
  • 72 Answers
SOURCE: How do I use a recorded voice message ringtone?
send the "sound" in a picture message to yourself, when you receive the message click options and click save as ringtone. easy as pie :) have fun any question dont hesitate to ask
Posted on Nov 21, 2008
  • 51 Answers
SOURCE: -Ringer is on 1. How to increase volume?
check wheather the phone is in silence mood and change the settings and then change ringer volume .
Posted on Jul 14, 2010
Avaya ip office 500 voice mail message fading in and out
Depending on which voice mail:
If you are using embedded mail then check connectivity with the line provider or upgrade system.
If you are using voicemail pro on a PC then check network traffic or connect PC directly to the IPO
Sep 16, 2013 | Avaya Embedded Voicemail for IP406 V2 and...
My voice mail stopped working since BT changed its IP address. The PC where the Avaya Phone manager is installed is connected to the network through this BT router. How can I restore the Voice...
What was changed? The IP address of the phone system or the IP of the voicemail PC?
You just need to go into manager and change the IP of where the voicemail is in the SYSTEM>VOICMAIL tab.
Mar 23, 2011 | Avaya 5400 Series 5410 Phone
Have the Microsoft Lifechat Lx 3000 headset, and I use Avaya IP Agent via VPN to work, and Windows 7 OS. I had a Logitech headset before and had same issue, so I don't think it's the headset. While trying...
I had the same type of problems using Avaya (road warrior set up - voip) through a vpn. I work at home on remote set up. I have tried changing headsets, using the telecommuter option in Avaya and going through my regular phone line and still had the same problem.
The company that I work for, suggested changing the order in which I log in to see if this solved the problem. I use to log into the computer first, and then double click on the vpn and enter my password and user name to start my work. They changed it to logging into the VPN at start up first and then continue to access my pc with the log in and password required for that purpose.
The sound quality is better using this method but it didn't stop the various sound issues that you spoke of in your question posted on fixya. It did reduce the number of problems experienced.
what I found that solved the issue for me was changing from the wired heatset on road warrior set up in Avaya to using my bluetooth headset from my cell phone instead.
My computer was not bluetooth enabled, so I went to Best Buy and bought an adapter by I/O Gear that works by plugging it in to your usb port on your pc. The adapter cost me less than $20.00. You install the software on your pc first, then put the adapter in your usb port and turn your bluetooth headset in to pairing mode. The computer picked up the signal quickly with my Plantronics Voyager Pro bluetooth headset. The sound quality is great. I am wireles and hands free for 300 to 550 feet and I have 9 hours of talk time after a single charge. This is a new set up for me. I have used it for about three weeks now and have not experienced any problems with hearing so far.
Give it a try.
Mar 21, 2011 | Microsoft LifeChatâ„¢ LX-3000 Headset
When i call or get calls with my avaya 4610sw you can hear my voice but i cannot hear yours
What system is this on. Usually one way voice usually indicates an IP problem....
Oct 12, 2010 | Avaya 4610SW IP Phone
My Avaya phone on our Avaya system only rings
ask your local admin to remove your phone from coverage path
Apr 15, 2010 | Linksys SPA941 IP Phone
Inbound call on avaya - phone on mute and you hit the headset button by mistake = will it record that you disconnected the customer? I got fired for hanging up on customers with the Avaya hard phone and...
No, that will not disconnect the caller. BUT, if you hit the headset button again, it will.
If you hit the headset button, you need to hit the switch hook to regain the call....
Apr 08, 2010 | Avaya 4610SW IP Phone
Magicjack
You have an IP problem.. Check the compression. One way voice is typical when the phone is programmed wrong.
Sep 18, 2009 | Avaya 5610 IP Phone
Unnatural voice quality
I think you answered your own question. DSL is not going to be very condusive to an IP phone.
Go to www.speedtest.net and see what your upload/download speeds are, my guess is there isn't enough bandwidth for the home data and voice....
Mar 22, 2009 | Avaya 4610SW IP Phone
I can hear my own voice on the headset of the Avaya 4610sw.
Try to keep the mic at a disttance and spek if you keep the mic near or the volume high you will definatly get that problem......
Dec 01, 2008 | Avaya 4610
Lands Phones Logo
76 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
