Question about HP Deskjet D1341 InkJet Printer
Printer has new ink cartridges it is connected properly and it does not print .
    President:
  • 1,194 Answers
Thanks for using Fixya.
Check for any pending documents.
When you connect your printer, an icon will pop in the try (at the bottom of the screen where the clock is located). Click on it and see if there are any documents in the list. If yes then cancel them all. Now restart your computer and then again give a print command.
If there were no pending pending documents then try to re-install the printer's software.
This will solve your problem.
Good luck and have a nice day.
Posted on Aug 04, 2010
I cannot print after install the driver
After installing the printer driver did you do a test print?
If it did not do a test print then either the wrong printer driver was installed or the printer cable is not connected properly or the ink cartridges was not installed properly. New ink cartridges need to have the air hole protection stickers removed.
Mar 12, 2013 | Office Equipment & Supplies
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
    I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
    Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
    U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
    Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
    U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
    Install the proper ink cartridge.
    Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
    If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
    Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
    Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
    Replace the ink cartridge.
    By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
    Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
    - images edited on the computer
    - images in a format other than JPEG or TIFF
    - images with double-byte characters used in the file name
    - images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
    Disconnect the cable between the printer and the camera to clear the error.
    Confirm the following items and print again.
    1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
    If the camera does not support either one, the printer cannot print directly from the camera.
    2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
    Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
    3. There may have been no response from the camera for the prescribed time.
    Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
    Press the OK button to clear the error.
    Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
    The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
    About ten minutes later, plug it in again, and turn the printer on.
    If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
    Press the OK button to release the error.
    Check the followings and do automatic print head alignment again.
    - Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
    - Check if the paper output slot is not exposed to a strong light source
    - Print the nozzle check pattern to check the status of the print head.
    If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
    1. Confirm that unusable paper is not set.
    2. Confirm that paper is set properly.
    3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    4. Cleaning the paper feed roller may resolve the error.
    If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
    If paper jam frequently occurs, check the following:
    1. Confirm that no foreign material is inside the printer.
    2. Confirm that unusable paper is not set.
    3. Confirm that paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
    Dec 27, 2009 | Canon Office Equipment & Supplies
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Error Message U053
    Error messages displayed on the LCD and how to handle them
    When an error has occurred in the printer, the error / check message is displayed on the LCD.
    Take the appropriate action to return to the normal condition.
    Error / Check message How to correct CHECK INK
    U041 An ink cartridge is empty.
    To cancel printing, press the Stop/Reset button.
    To continue printing, press the OK button.
    After the printing finishes, replace the empty ink cartridge.
    Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
    I cant print it is showing e5 on printer screen
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    tokio-3
    Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Ink cartridge replacements.
    Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
    Hope this helps. Bud
    Jan 08, 2009 | Dell 926 All-In-One InkJet Printer
    Colored Ink problem
    Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
    Jun 08, 2007 | Lexmark Color Z35 InkJet
    HP Deskjet D1341 InkJet Printer Logo
    23 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
