Question about Maytag M7Q08F2ACOM Air Conditioner
How to clean dirt that gets by filter of window air conditioner M7Q08F2A
  • Maytag Master
  • 3,289 Answers
Both the evaporator and condenser coils (inside and outside) can be safely cleaned with products specifically made for the job. Clean evaporator and condenser coils mean more efficient cooling - which means lower operating costs. Cleaning the coils can remove stale or other less desirable odors that originate from your air conditioner. An example is made by Thermwell which is available at Lowes and other hardware and home improvement stores. There are many different manufacturers of the cleaners - so if this particular brand isn't available at the store you shop, another will do. Different brands and types have different methods - so you should read and follow the directions on the can. Many of the canned foaming / spray type cleaners are "rinse free" - meaning it is not required to rinse the foam off - as running the unit will allow the condensation that forms of the coils to do the rinsing for you. It should be noted that window / thru the wall types and other non-central air conditioning units should be tilted so that the condensation and chemicals drain outside - not into the house. If your AC hasn't been dripping water inside, it should be fine. Usually all that is needed is to remove the front grill and filter to access the coil. With the unit off (preferably unplugged) spray the foaming cleaner into the coil and let it sit to work on the dirt, grime, mold, nicotine, etc. that has collected on the coil. When the last step of the can's printed directions are complete - the job is done. You can find some helpful videos on Youtube to show how the cleaning is done on the larger, central air type units.
Please rate this reply if it was helpful to you - good luck!
Posted on Aug 04, 2010
Testimonial: "Thankyou. Very much appreciated Regards, JmcB"
I can not get the filter light to turn off after I cleaned and replaced the filter. I unplugged and reset the unit already.
If the filter was really dirty you could have plugged up the evaporator ( the thing you are trying to keep clean with the filter )
Try,removing the filter and using a spray bottle with a strong stream and spray into the evaporator to wash it out. If this does not work find a local appliance or refrigeration supply house and purchase a can of evaporator cleaner. When sprayed into the evaporator it should react with the dirt, foam up and remove the blockage
Aug 13, 2016 | Norpole 6000BTU Window Air Conditioner...
Maytag wall unit does not cool well
Maybe it's time for a new and more energy efficient unit. Those window units are cheap, but waste plenty of energy. Try a mini split!
Sep 03, 2013 | Maytag M7Q08F2A Thru-Wall/Window Air...
How to clean front cover M7Q08FZA
Spray with kitchen degreaser with filter gauzes out but cover closed. Allow to soak for 10 mins. Brush with nylon brush (dustpan brush) or old toothbrush to get into all the crevices then rinse with warm water from a garden low pressure sprayer and vacuum dry with a vacuum cleaner. Refit filters and run to check
May 17, 2012 | Maytag M7Q08F2A Thru-Wall/Window Air...
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
Can I remove the air filter to clean it or do I need to buy a new air filter to replace the old one?
i have a similar unit and noticed not much air was coming out and unit was not getting as cold so i looked at the filter and it had caked on dirt.So i removed it then it got my air compressor and went outside then blew all the dust from the unit now it works like new.Some people wash out the dirt but this ruins the filters.Make sure you wear something to cover your face from the dirt you would be surprised how much dust comes out of these units.
Jul 19, 2010 | Pelonis KCD-25YI Air Conditioner
Some discharge coil in window ac effectiveness is reduced.what mi
Clean the air filter. It can be removed and ran under water. If the coils are dirty take the window unit out side, remove the cover and house out the coils. Be careful and try not to get a lot of water into the switches. Make sure it's dried out really good before plugging it back in. The number one problem for A\C units is dirt.
Apr 19, 2010 | LG Heat cool Window Air Conditioner
Air conditioner wont work after winter off
Make sure the filter is clean. When you remove the filter you should be able to see the evaporator coil. Make sure it's not clogged with dirt. If they are clean is the fan and compressor are running. If they are not working and with the cost of repair if no warranty. It's time for a new window unit.
Apr 19, 2010 | LG LB1200ER Air Conditioner
Air conditioner is freezing/icing up inside
needs to be taken apart and clenaned
Jun 21, 2009 | Heating & Cooling
Air does not come out
These are a few questions you must ask yourself. Is the fan motor running. Is the evaporator & blower motor clean
May 18, 2009 | Maytag M7Q08F2A Thru-Wall/Window Air...
"Check Filter" light is on
Take out the filter and pour water on the oposite side that is the dirt,if the water is not enough use degreaser and also clean thefront cover where the filter goes.
Apr 04, 2009 | Maytag M6Q10F2A Air Conditioner
Maytag M7Q08F2ACOM Air Conditioner Logo
202 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
