Question about Security ST7000 Alarm W 1 Birt Relays
I bought a package car alarm/remote lock kit from Sunmmit a while back and are just getting around to installing it. The instructions are terrible! There is a wiring diagram only and it does not explain anything about wiring the alarm in with the locks, how to wire to the door triggers, etc. Can you help me with this? The Hoffman Group website is also no help and the tech line doesn't answer....go figure!
  • rabbits4u Aug 04, 2010
    Quick response, good answers.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links …if it helps…
http://www.ehow.com/way_5732357_car-remote-start-installation-instructions.html
http://www.ehow.com/how_3684_install-car-alarm.html
http://www.defa.com/doc/InstallationManualx800series.PDF
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 04, 2010
    Thanks, I will check out those links. I did finally wait out tech support from Hoffman and they talked me through it also. Turns out I need two more relays not included in the kit to make it work. It is pretty hard to install a "kit" when they don't sell you all the parts you will need to make it work. Thanks again...
Remote start/ 09 Camry installation
what brand is alarm? hood pin IS required,ground hood pin lead try to remote start
If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Jan 18, 2013 | Brand Remote Start/keyless/car Alarm Very...
2003 fx35 door lock problems
The problem is the Door lock actuators and when I went to the dealer they want $467.90 to fix just my driver's side door, but after almost having a heart-attack from the dealer's estimate, I checked on ebay and found a Kit to fix the door lock for only $59 so i ordered one kit (shipping was super fast) it came with very easy instructions on how to install the kit, so I installed about 4-months ago in under 1HR and now everything is Back to normal, I can unlock/Lock using my original OEM key fob and also using the power switch on the door, so everything work as from factory ( no need for aftermarket alarm or remote) ... !!!! here is a link of the kit that I purchased. The seller is green-seller1975 and item #111291472359
Aug 21, 2012 | 2003 Infiniti FX35
Bought a 1995 jeep grand cherokee orvis . it has no keeless remote, just keys.installed new battery and the security must be on.all lights inside and out are blinking.on and off. how do i reset security.
Try turning the key..unlock-lock-unlock in the rear tailgate lock. That should turn off the factory security system.
If it's an aftermarket alarm system, you will need an alarm installer's help in determining what type and model alarm it is, before you can figure out how to shut it off.
Feb 05, 2011 | 1995 Jeep Grand Cherokee
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Need remote for alarm dealer installed
go online and look up replacement remote...you can reset it to your code easy with instructions that come with kit. around 65 bucks
Jul 09, 2010 | 1999 Toyota Camry Solara
No instructions for installing car alarm
hello guys i bought a nitro 422bmw 2-way alarm system and i didnt get the manuanl for this alarm system , the code for the this alarm system? can you please help with this solution? my name is joey? thank you guys
Jul 29, 2009 | Scytek 2000RS Remote Control
1995 Nissan Maxima alarm system
Hey, I bought my 1995 Nissan Maxima GLE brand new back in July 1994 with factory installed alarm, it just doen't make any sound when you arm or disarm it with remote. The only way you can tell whether it is armed or disarmed is from the lever position of your doors and the blinking red light under the dash. Only the newer versions of Nissan/Infiniti's has the "Audio/Silent" mode button on the remote which allows you to activate/deactivate you car alarm with an audiable sound or no sound at all. No worry, there is nothing wrong with your remote or car alarm.
Jun 17, 2009 | 1995 Nissan Maxima
Keyless entry system installation
The esiest way will be to ad an aftermarket central lock motor to your cars drivers door you can buy these seperatly at most alarm shops for a few dollars ,the idea is that you can hook up your ebay kit directly to this motor and this motor will drive the cars central locking.The aftermarket motor hooks up to the lock button rod in your drivers door.You will see this rod moving when you remove the trim and lock and unlock yhe door via the up/down button/knob.
Apr 07, 2009 | Vehicle Parts & Accessories
Viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Dec 21, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Security ST7000  Alarm W 1 Birt Relays Logo
51 people viewed this question
Top Stellar Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
Terry Hair
Tom Chichester
Are you a Stellar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
