Question about LG WM-2277HW Front Load Washer
Lg washer 2277, spin cycle
I just got my new washer a dryer, I have never had front loads before, but on the rinse cycle it just hums and does not spin. It will start working after a few minutes. Is this normal, hate to sound dumb but I just want to make sure it is working right.
  • 489 Answers
The humming noise is probably the drain pump working to remove the water out of the tub.  It is normal.
Posted on Apr 27, 2008
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Spin cycle appears to be broken. washer just hums
Humming can indicate a stalled motor...If a coin is jammed in the pump impeller it will often do what you describe...Check via pump filter access door...Good luck....Nomess
May 08, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine doesnt rinse and spin
IT SOUNDS AS THOUGH ITS NOT HEATING IF IT DOESNT IT STAYS IN WASH MODE AND WONT COMPLETE CYCLE NEW HEATER REQUIRED
Aug 12, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Lg 2277h won't spin
More than likely, you have a problem with the balance ball sensor in the back of the unit if it so equipped.  It is located in the back of the unit and will require an LG qualified tech to see what's going on.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
LG WM-2277HW Front Load Washer Logo
246 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
