Question about Samsung SyncMaster 213T 21.3" LCD Monitor
My 213T monitor began to darken on the lower third of the screen about one week ago. Two days later the screen went completely black. I pulled the back off and found three capacitors positions C-012, C-013 and C-014 on the BN41-00296B (Power Supply - Inverter?)board are bad (their tops are extended). Do you think this might be the problem. Is there any other places I should look? Thank You Dave
  • 19 Answers
Your unit has bad caps in the inverter and the power supply. The bad caps in the inverter causes a mosfet to short out and this blows the inline fuses on the inverter. After the fuses blow, the power light will still go on but there will be no power going to the inverter. It is possible to repair this damage, I have fixed over 40 of this model monitor. You can find more info by searching this model on badcaps . net. I can be contacted there as user 'bluto'
Posted on Nov 19, 2010
  • 11,361 Answers
You found the problem, it is very common for all LCD monitors.
http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
He can make you a set of caps for you.
Posted on Aug 05, 2010
A few days ago noticed my C7 was dark at top of the screen like a shadow. Touch screen works fine. Several days later the shadow has slowly spread down the display leaving the top third of the screen...
Sometimes when we are wearing tight clothes and put mobile phones in the pocket, the screen gets pressed against coins or keys in the pocket. This damages the screen. I think this is the case with you. Now, the only solution remaining is replacing the LCD.
Sep 11, 2011 | Nokia C7 (8 GB) Smartphone
My screen has gone blank. It fell on the floor a few days ago, but only this morning it began to go "funny" and now it is completely blank (black). Any ideas how to fix it please?
bad sign... when the CP turns black, the CPU IC maybe damaged... an expert cellphone technician may fix it but it have a 50-50 chance or best to buy a new CP... sorry for your broken CP... but still hope that it can be fix or if you can afford a new one...
May 25, 2010 | Samsung SGH-G800 Cellular Phone
I've had my monitor for years with no problems. Today, when I turned on my computer, the monitor flickered. Then the screen went black, and the power button began blinking (green). When I turned it off...
A couple of things to check. First make sure that all the connections are in place. That is, the one at the PC and the one on the back of the monitor. Second - Make sure that the video card is seated correctly in the PC. Third - Replace the monitor cable. Fourth - Check with another monitor, if possible.
Mar 27, 2010 | Dell E153FP 15" LCD Monitor
My screen began to take longer and longer to come on in the morning, up to 5 minutes. Then throught the day if my computer went on standby power, it would take 2-3 minutes to come back up..(and both ways...
kvons, Your monitor's behavior common to all brands not just Samsung. May need servicing by electronic technician. Read my and other tech's FIXYA profiles about solutions to BLACK screen problems and the two most common failure modes. 12fixlouie
Feb 04, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My Samsung 213T monitor went black. Power light
I will not be surprised that it will be bad capacitors, that is the first place to check, see some samples here: http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Jan 04, 2010 | Samsung SyncMaster 213T 21.3" LCD Monitor
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
Was searching the web and screen went black,,power light is on but no screen,,no menu screen,,cant hit auto seek,,nothing,,to me seems like the tube is blew out,,any suggestions?repair price?
whats the light on the towere if the light is stedy green then the tower is ok so unplug the data cable from tower and turn on the monitor then if it run the self test then monitor is ok if its not yiu need to repair or replace the screen
Jun 26, 2009 | Samsung SyncMaster 213T 21.3" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Lacie 19" Electron Blue - Black screen with a brilliant white line across
I have 2 of these monitors and have this problem. I was so frustrated turning the monitor off and on until the white line disappeared that one day, I punched the screen. And it worked! So now whenever this happens (about once every other day) I use my palm and smack the lower left corner of the monitor until the white line disappears. I like the color on these screens so I don't want to replace them until I have to. I will NOT buy another Lacie though.
Sep 13, 2006 | LaCie Electron 19" CRT Monitor
Samsung SyncMaster 213T 21.3" LCD Monitor Logo
520 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
