Question about Miele Novotronic Premier 500 Front Load Washer
My miele w842 starts its programme and then the rinse light flashes stops then flashes again and the finish light comes on and drains the water out i have changed the brushes and the same thing happens can you help?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
Firstly check the brush module is correctly located this can be done with a multimeter. you should get continuity between sets of pins. first pin on right of module is earth moving to left next two are the overload(continuity) next three are field coil windings(continuity between at least 2 out of 3 spin speed dependent) next two are brushes(continuity) next two are the tacho.(500 ohms) If this checks out OK. Then most likely you require new power electronic which clips on the back of control electronic
Posted on Aug 09, 2010
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
The diswashing programme starts intermittently and does not go to the end of the washing programme and the washing is luke warm. I have checked and cleaned all filters and checked the water...
I suspect the pump or outlet hose is partially blocked, is it emptying in normal time with a normal outlet flow? (You can check that by watching the water come out if you can see the drain). Does the flashing light have a label on it, the lights on miele are generally labelled.
When you say it starts intermittently do you mean you have to start it more than once to be successful? That again would point to a pump or outlet hose blockage as it has to purge any water before starting.
Difficult to diagnose without more clues.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Miele Dishwashers
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Miele rinse light keeps flashing
did you check the DRAIN PUMP MOTOR ? IT COULD BE CLOGGED or something blocking the impellers
Apr 19, 2008 | Washing Machines
Miele Novotronic Premier 500 Front Load Washer Logo
908 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
